I know this is a kinda of a late reply but I hope it helps someone.
Only Okuma post I have.
Someone has the post processor OSP P300M OKUMA to MasterCam 2018 to share?
Thanks in advance
Hello TampaCNC, thank you for the okuma post files !!! Did you tested some of this post processor?
works fine for me.
hey do you have post for lathe as well ?OSP? U100L or OSP7000?
Do you have post processor for Okuma OSP P300LA to mastercam? thank you
First of all thanks a lot!!! But unfortunately they are made for a 2018 version of MasterCam. I’m using the X9. The first bundle you’ve posted on this thread works fine but it’s for a simultaneous 4 axis machine and im running a normal 3ax. Thank you for your help anyway! Just in case, if you have something else to try do not hesitate to post it!
Thank you!
M.
Inviato dal mio iPhone utilizzando Tapatalk
No problem. I know it can be frustrating not knowing what to do.
Hello, maybe you have already found a post for Okuma P300LA? If so, could you share it? Thank you
serega7hsh@gmail.com
hola necesito post procesador para mastercam a nivel de torno y fresa para okuma p300 O P200 muchas gracias
LUISANTONIOROD@HOTMAIL.COM
Hello TampaCNC. I’m looking for the lathe OKUMA LB 300 , OSP U100l post processor. Do you have something to share? You would definitely give me a huge favou1
thanks man
