Build Thread Making PostProcessor for Planet CNC TNG.
Results 1 to 1 of 1
Thread: Making PostProcessor for Planet CNC TNG.
    Jun 2017
    Norway
    Default Making PostProcessor for Planet CNC TNG.
    Hello.
    I am making a new post processor for the Planet CNC TNG software. I've had some issues with the post processor that is supplied with the software.
    I have added the post processor and a test file from sheetcam with G code.
    Can anyone tell me if this G code would work ?
    N0070G00 X6.3880 Y6.3880
    N0080 M08
    N0090 M11P0 G38.2 Z-1000 F1250
    N0100 G91 G01 Z-1.6
    N0110 M11P1 G90
    N0120 M72
    N0130 M71
    N0140 G00 Z3.8000
    N0150 M03
    N0160G04 P0.2
    N0170G01 Z1.5000 F2500.0
    The post is with Floating head, but I am unsure if the code in here is correct. Any ideas?
    Also in the post processor I tried adding settings in the start like "Switchoffset and Workoffsetspeed" and then using the code below:
    --Put your switch offset value here in MILLIMETRES
    switchOffset = 2.5
    post.Text (" M11P0 G38.2 Z-1000 F#<Workoffsetspeed>\n")
    post.Text (" G91 G01 Z[+#<Switchoffset>]\n")
    But this did not work. Any tips here? I would like to make it so people can add settings in the beginning of the pp that will be referenced in the code itself. I would also like to add "reference distance" if the torch has travelled x amount.
    Attached Files Attached Files
