Sheetcam Problem - Mach3 strange artifacts in gcode.
Results 1 to 3 of 3
Thread: Sheetcam Problem - Mach3 strange artifacts in gcode.
    May 2016
    Default Sheetcam Problem - Mach3 strange artifacts in gcode.
    I'm trying to test my plasma cutter and having a bit oh trouble with the post processing,
    Could anybody help me by identifying the reason that my post processor keeps putting these circles in my gcode, When I use the simulate in sheet cam it's not there but when I load it into
    Mach3 it then appears, see the picture below...
    I'm running a floating head, and using the mach3 plasma & stencil THC and also the mp1000 THC.
    Code? NO180.....................???
    .[IMG]https://www.cnczone.com/forums/attachment.php?attachmentid=440866&stc=1[/IMG]
    Attached Thumbnails Attached Thumbnails Sheetcam Problem - Mach3 strange artifacts in gcode.-untitled-jpg
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Sheetcam Problem - Mach3 strange artifacts in gcode.
    Try changing the IJ mode in general config.
    UCCNC 2017 Screenset
    May 2016
    Thanks, im a noob :)
