- Alphacam POS SCM Xilog3 3d Surface xyz
$----------------------- MACHINING FEED MOVES -------------------------------
$40 Machining FEED lines
$MODAL OFF X Y Z
$IF ABS(IZ)>0
$ELSEIF FF = 1
C[TC]
G0 X=[CX] Y=[CY] Z=[CZ] V[RAPID_FEED] S[S/1000] T[T]
G1 X=[AX] Y=[AY] Z=[AZ] V[F]
$ELSE
$ENDIF
This are correct for 2d machine but don't work on surface machice in SCM 3xis xilog
Someone Help me.
Re: Alphacam POS SCM Xilog3 3d Surface xyz
Dear,
i think i have same problem.
You need make some Z interpolation or work on 3D surface?
Which post for alfa you have and which machine?
- You may not post replies
- You may not edit your posts
Forum Rules
