Hello. I was hoping to get a little direction as to what postprocessor to use.
I currently run SheetCAM and Mach3, with a MiniTHC on a Protorch table.
I have been cutting parts and art very well but recently built in a Floating Head. I am trying to utilize the floating to zero the Z axis on every pierce.
I was curious what Postprocessor I should use with the floating head. I tried a few of the postprocessors and the one I had the best luck with was "Mach3 THC with Scriber".
I edited this postprocessor to my switchoffest of 6.1mm (0.24"). But I can't get the torch head to come down and reference the material before the pierce. Below is a sample of the G-code generated.
I must admit that I am very new to the G-code side of things.
Thanks in advance for the help,
Scott
N0010 (Filename: Hannah fhtest.tap)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 6/17/2018)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: Hannah)
N0080 (Operation: Outside Offset, C-ANNO-MATC-PATT, T1: 45AMP 14G MS)
N0090 G00 X4.5065 Y2.7228
N0100 G28.1 Z0.12 F19.685
N0110 G92 Z0.0
N0120 G00 Z0.2402
N0130 G92 Z0.0
N0140 G00 Z0.1000
N0150 M03
N0160 G01 Z0.0600 F130.0
N0170 X4.6330 Y2.8033 F100.0
N0180 X4.6383 Y2.7734
N0190 G03 X4.3929 Y2.4137 I0.2509 J-0.4348
N0200 X4.6127 Y1.5964 I0.9018 J-0.1956
N0210 G01 X4.6131 Y1.5960
N0220 G03 X4.8671 Y1.4713 I0.2961 J0.2821
N0230 G01 X4.8792 Y1.4029
N0240 G02 X4.3563 Y1.7350 I0.0381 J0.6377
N0250 G01 X4.3556 Y1.7362
N0260 G02 X4.3533 Y2.6397 I0.7280 J0.4535
N0270 X4.6248 Y2.8500 I0.4461 J-0.2954
N0280 G01 X4.6330 Y2.8033
N0290 G02 X4.5065 Y2.7542 I-0.0878 J0.0387 F40.0
N0300 M05
N0310 G00 Z0.3937
N0320 X5.1609 Y1.5369
N0330 Z0.1000
