Need Help! Need to figure out were i went wrong
Results 1 to 2 of 2
Thread: Need to figure out were i went wrong
    Dec 2007
    Default Need to figure out were i went wrong
    Hi all i am trying to modify this little bit of code on my post and it keeps throwing a error , i sure could use some help with this it starts after Lathe return string (G99), iwas trying insert the G96 code .
    I am not sure what i should have put after the G99 ? and then how to end it ?
    If MILL_GetUserSelectComboVariable(0) = 0 Then
    Lathe_SetReturnString("G98")
    Else
    Lathe_SetReturnString("G99")
    Then
    Lathe_SetReturnString("G96")
    End If
    Thank You in advance
    Member Maroslav4's Avatar
    Apr 2015
    Czech Republic
    Default Re: Need to figure out were i went wrong
    [QUOTE=woffler;2184526]Hi all i am trying to modify this little bit of code on my post and it keeps throwing a error , i sure could use some help with this it starts after Lathe return string (G99), iwas trying insert the G96 code .
    Else
    Then
    End If
    Thank You in advance[/QUOTE]
    Hello,
    you have a programiing error. You cannot use your code.
    Correct can be this.
    [COLOR=#000000]If MILL_GetUserSelectComboVariable(0) = 0 Then[/COLOR]
    [COLOR=#000000]Lathe_SetReturnString("G98")[/COLOR]
    [COLOR=#000000]Elseif [/COLOR][COLOR=#000000]MILL_GetUserSelectComboVariable(0) = 1 then[/COLOR]
    [COLOR=#000000]Lathe_SetReturnString("G99")[/COLOR]
    [COLOR=#000000]else[/COLOR]
    [COLOR=#000000]Lathe_SetReturnString("G96")[/COLOR]
    [COLOR=#000000]End If[/COLOR]
    but it is also not good. Not sure what is your all code. It is only example.
    You cannot use
    If some_variable = true then
    "do something"
    else (in this line you say if "some_variable = true" do someting else)
    "do something else"
    then (it is syntax error)
    endif
    Hope understable
    Marek
    Postprocessors, VBA macros, .NET programming.
    www.ccsoftcz.com
