Here is a couple of signs
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Here is a couple of signs
    Registered Pplug's Avatar
    Jan 2007
    Default Here is a couple of signs
    I mainly do signs to pay for christmas. Here are a few examples I have done for people and businesses. Most of these were made in my converted Omis III CMM.
    Attached Thumbnails Attached Thumbnails Here is a couple of signs-example2-jpg   Here is a couple of signs-example1-jpg   Here is a couple of signs-example3-jpg   Here is a couple of signs-example4-jpg
    Here is a couple of signs-example5-jpg   Here is a couple of signs-example6-jpg
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Registered DIYaholic's Avatar
    Oct 2009
    Pplug,
    Nice looking work.
    Seeing them motivates me towards completing (starting) my own cnc router machine build. I'm currently researching my own build and waiting to move to a new residence with shop space.
    Again, nice job and thanks for posting and the motivation!
    Randy,
    I may not be good....
    But I am S L O W!!
    Sep 2007
    us
    Pplug,
    very nice work, I too work as a sign maker, but nothing this fancy, i am barely crawling when you are already flying, thank you for posting these images
    Member SScnc's Avatar
    Jun 2008
    Pplug, Absolutely beautiful work ! The details and textures are amazing, like the weave around "The Harts".
    Great work !
    Registered abomb55076's Avatar
    Jan 2006
    What type of software are you using for the 3d graphics such as the dog and the weave in the backgrounds?
    Jan 2007
    Currently I'm using artcam but I think I will be switching to vectric aspire when my version of AC becomes too dated. Its cheaper and does everything I think I need it to.
  7. #7
    Gold Member
    Mar 2004
    The basket weave pattern you used in a few of them is really slick. Never seen that done before. Nice work.
  8. #8
    Jan 2010
    St. Lucia, W.I.
    Beautiful , very inspirational, work
  9. #9
    Dec 2007
    Very artistic I am jealous.
  10. #10
    Gold Member doorknob's Avatar
    Jan 2010
    Maybe this is OT, but I'm wondering how you would determine what to charge for work like that.
    They're complex enough that it might be difficult to do an accurate estimate in advance, but it's hard to convince a customer to pay an open-ended hourly rate...
  11. #11
    Jan 2007
    Quote Originally Posted by doorknob
    I usually charge about $20-$30 an hour. It usually takes about 10-20 min to design and produce the tool paths. I usually double the price for painting & finishing. Typically a sign can run from $135 to $250.
    I can give the customer a very accurate idea of the routing time. The techno interface preprocesses the g-code file and the new beta interface is accurate to the second. I can run a simulation in mach3 and it is accurate as well. Of course this is for custom designs. Most of the Picts are of basic templates with added text at preset hieghts and I know about how much time they take.
  12. #12
    Member kolias's Avatar
    May 2009
    Nice work pplug
    I just finished my CNC machine and although I have no problem making a sign just for a hobby I'm lost when it comes to paint it.
    How do you paint the letters? Like if I want to have the surface one color and the letters another color how do you do that?
    Nicolas
  13. #13
    Jan 2007
    Most of the time I just paint the tops of the letters. I am working on a method using a vinyl cutter to create a mask that would let me spraypaint the sides as well without hitting the background. I haven't tried it yet.
  14. #14
    Oct 2010
    I'm new to routers, but I use a laser for my signs. For 2 colors I'll paint the raw material, then mask it with vinyl sign transfer tape, engrave it, spray it with color #2 then unmask the material.
  15. #15
    May 2009
    Quote Originally Posted by bpoulin View Post
    I didn't know about this vinyl sign transfer tape. sounds a good idea
    Nicolas
  16. #16
    Registered cheetahcnc's Avatar
    Oct 2007
    Real nice, amazing what fantastic work lies beneath ordinary wood
  17. #17
    Oct 2010
    Here is a single color masked then I just burned the wood with the laser. Here is where I get my masking Sign Warehouse And if that doesn't work they have vinyls specifically for spray masking, or sandblast masking I haven't experimented with any of these and a rotary cutter, it might take some experimentation.
  18. #18
    May 2009
    Hey bpoulin, that’s the best info I got so far, thanks for the info
    When you say “I just burned the wood with the laser” what guides the laser? I mean do you have the gcode or another code for this sign on your laser?
    Nicolas
  19. #19
    Oct 2010
    It's a Chinese CNC laser engraver, 1200x800mm cutting area. Check out the laser engravers forum here on CNCzone.
  20. #20
    May 2009
    Sorry bpoulin, I know about the Chinese Laser Engravers. What I dont know is how the engraver knows where to burn the wood on that sign.
    Nicolas
