Need Help! Language change Zimmer+Kreim 850 EDM mashine
Results 1 to 4 of 4
Thread: Language change Zimmer+Kreim 850 EDM mashine
    Member Foreigner1976's Avatar
    Sep 2023
    Default Language change Zimmer+Kreim 850 EDM mashine
    Sep 2023
    Thumbs up Re: Language change Zimmer+Kreim 850 EDM mashine
    I answer my own question.
    To change the interface language to English, you need to go to the Machine parameters menu from the main menu (photo 1), go to item 6 (photo 2), enter the password (photo 3, in my case it is 1603, look for it in the documentation for the machine), using the F1-F4 keys go to item 189, use the F5 key to change from AUS to EIN.
    Press F7 to exit. That's it, now you have English (photo 6).
    P.S. I really liked this machine, despite the fact that it was made in 1996
    Attached Thumbnails Attached Thumbnails Language change Zimmer+Kreim 850 EDM mashine-1-jpg   Language change Zimmer+Kreim 850 EDM mashine-2-jpg   Language change Zimmer+Kreim 850 EDM mashine-3-jpg   Language change Zimmer+Kreim 850 EDM mashine-4-jpg
    Language change Zimmer+Kreim 850 EDM mashine-5-jpg   Language change Zimmer+Kreim 850 EDM mashine-6-jpg
    Sep 2015
    Default Re: Language change Zimmer+Kreim 850 EDM mashine
    I am very happy for your post about ZK850. I have a same machine, I bought 2 years ago but didn't use it. Unfortunately I haven't got any expirience with this machine. I am using AGIE and Deckel for cavity EDM and Fanuc for wire. I will try the change of language because I don't speach german.
    Unfortunately the machine don't begin, it forgetted the system parameter. I have some floppy with system files but the floppy driver can not read anything......I will suffer continue.............
    Sep 2015
    The change of language to English is successfull.................Thanks for introducing............
