Mitsubishi edm - system loading error - floppy disks erased?
Good day folks, i hope you can help me, i just want to ensure that the software, pitch and epaks discs arent erased for a mitsubishi dwc 100, i have a floppy-usb reader and im using win10, but i read something about the cp/w format and is only readable in win95... is it true? because it didnt recognize any disc.
I did the procedure according to the manual, up swith up and down switch down, dip switch #2 on and all other off, and then reset, but it stays on system loading error (machine was stored months with no working acid battery).
Disc are from 89 so i know that data lost the most probably reason... so if thats the case, to whom do i have to send an email? what branch of mitsubishi? Thanks in advance, just need a little guidance.
