New Machine Build CNC Plasma 4x8
Results 1 to 7 of 7
Thread: CNC Plasma 4x8
    Jan 2014
    Default CNC Plasma 4x8
    Hello!
    I will present my build of a 4'x8' Plasma table. The mechanics is my own design and the electronics is a kit from CandCNC. It uses a Hypertherm Powermax 45 Plasma cutter.
    I have made a CAD model and building instructions which you can find here:
    https://grabcad.com/library/cnc-plasma-16
    The building instructions is also attached in this post
    CNC Plasma 4x8-plasma_cover_4x8-jpg
    The mechanics consists of fixed AT5 belts, 25mm wide. The step motors is Nema 23 4,4 Nm (620 oz inch). With a 3:1 belt reduction(HTD3M belt) and a 15 tooth pulley on the AT5 belt, the motion is 25 mm per revolution of the step motor. This was the gearing recommended by CandCNC. The gantry weighs around 40 kg (excluding step motors). The linear bearings consists of TBR16 linear rail along the gantry and v-groove bearings for the gantry motion. The CNC software is Mach 3 on a windows xp computer.
    Attached Files Attached Files
    Sep 2005
    Default Re: CNC Plasma 4x8
    Fantastic job Peter.
    Already have my table built but love to see a great set of plans to think about what I could have done better.
    Thanks very much.
    Jan 2014
    The frame:
    CNC Plasma 4x8-img_0134-jpg
    CNC Plasma 4x8-img_0930-jpg
    Sidewagons for the gantry:
    CNC Plasma 4x8-img_0933-jpg
    CNC Plasma 4x8-img_0935-jpg
    CNC Plasma 4x8-img_0936-jpg
    CNC Plasma 4x8-img_0938-jpg
    CNC Plasma 4x8-img_0939-jpg
    Jan 2014
    The X-axis wagon is attached on the gantry:
    CNC Plasma 4x8-img_0946-jpg
    CNC Plasma 4x8-img_0948-jpg
    The AT5 belt is attached:
    CNC Plasma 4x8-img_0950-jpg
    CNC Plasma 4x8-img_0952-jpg
    The torch holder, mounted on the Z-axis:
    CNC Plasma 4x8-img_1038-jpg
    CNC Plasma 4x8-img_1039-jpg
    CNC Plasma 4x8-img_1040-jpg
    Some testing of the electronics:
    CNC Plasma 4x8-img_0992-jpg
    Jan 2014
    Building of table for electronics, plasma etc:
    CNC Plasma 4x8-img_1050-jpg
    CNC Plasma 4x8-img_1051-jpg
    CNC Plasma 4x8-img_1052-jpg
    Almost finished:
    CNC Plasma 4x8-img_1055-jpg
    CNC Plasma 4x8-img_1056-jpg
    magnetic torch breakaway:
    CNC Plasma 4x8-img_1334-jpg
    Limit switches:
    CNC Plasma 4x8-img_1182-jpg
    CNC Plasma 4x8-img_1183-jpg
    Jan 2014
    CNC Plasma 4x8-img_1352-jpg
    CNC Plasma 4x8-img_1353-jpg
    CNC Plasma 4x8-img_1356-jpg
    First project, a spider:
    CNC Plasma 4x8-img_1344-jpg
    CNC Plasma 4x8-img_1361-jpg
    CNC Plasma 4x8-img_1362-jpg
  7. #7
    Jan 2014
    Video of some cutting.
CNC Plasma 4x8
CNC Plasma 4x8
