Need Help! about omni 2040 plasma cutter
Results 1 to 2 of 2
Thread: about omni 2040 plasma cutter
    Jan 2015
    Default about omni 2040 plasma cutter
    i have a omni 2040 plasma cutter with hypertherm 65A with a CC-M3 controller and start shaphon torch controller , it looks like i've lost manufacturer parameters and every thing is just wrong with my machine now , can any one help with that?? thanks a lot!!!!
    Banned
    Dec 2019
    Default Re: about omni 2040 plasma cutter
    Try to contact a specialist, I think he will definitely be able to understand this. If you don't know any specialists, try contacting the manufacturer's support. The ideal course would be to find the instructions. My uncle worked as a welder for quite a long time, so maybe I can find out from him about this issue. Although he did not study to be a welder and did not take any courses. Just your own experience and detailed guidance at prowelderguide.com which explains a lot of nuances in welding. Try to read the guide, I think you will definitely find the answer to your question in it
