Cnc plasma ( water cooled or air cooled )
Results 1 to 4 of 4
Thread: Cnc plasma ( water cooled or air cooled )
    Default Cnc plasma ( water cooled or air cooled )
    I've chinese plasma cutting machine. I'm new to plasma cutting. I've a question how to decide that i should use air cooled tip or water cooled plasma tip ?
    I should use water filled up in my table 'pictures attached ' or my table should be dry ?
    I tried to cut 3mm mild steel at 45 amps and 3000mm per minute and it damaged my table grill .
    I'm really confused.
    Cnc plasma ( water cooled or air cooled )-uploadfromtaptalk1522851596130-jpgCnc plasma ( water cooled or air cooled )-uploadfromtaptalk1522851608778-jpgCnc plasma ( water cooled or air cooled )-uploadfromtaptalk1522851619455-jpgCnc plasma ( water cooled or air cooled )-uploadfromtaptalk1522851627600-jpg
    Oct 2004
    Default Re: Cnc plasma ( water cooled or air cooled )
    My plasma torches were always air cooled. Water cooled sounds like a good idea, maybe complicated tho. The grill under the sheet is expendable, expect to replace the slats occasionally.
    Quote Originally Posted by greggv View Post
    Cnc plasma ( water cooled or air cooled )-uploadfromtaptalk1522853896512-jpg
    Why this blue pipe is here ?
    While cutting 8mm mild steelsheet with plasma, cut is at angle of 45 degree from 2 sides while other 2 sides are at 90 degree. How i should make 45 degree to 90. Current is 100 amps and speed is 500mm/min.
    Sent from my SM-J710FN using Tapatalk
