Need Help! Excetek E500 wire EDM prolme
Results 1 to 3 of 3
Thread: Excetek E500 wire EDM prolme
    Sep 2016
    Pakistan
    Default Excetek E500 wire EDM prolme
    hello
    i hope all is good, dear friends i have facing a problem in Excetek wire cut Model E 500, Year 2007. problem is machine interface says " over usable time, pleas enter password" i don,t have idea waht is password . if any one have idea about this machine. pleas tell us .thank you
    best reguards
    TEHMAS FIAZ
    Attached Thumbnails Attached Thumbnails Excetek E500 wire EDM prolme-img-20180311-wa0012-jpg   Excetek E500 wire EDM prolme-img-20180311-wa0016-jpg   Excetek E500 wire EDM prolme-img-20180311-wa0019-jpg   Excetek E500 wire EDM prolme-img-20180321-wa0016-jpg
    Excetek E500 wire EDM prolme-img-20180311-wa0026-jpg   Excetek E500 wire EDM prolme-img-20180321-wa0014-jpg
    Nov 2008
    Argentina
    Default Re: Excetek E500 wire EDM prolme
    Dear Themas,
    I'm having the same problem with a Sure First Wedm, wich has the same system as your machine. Could you solve the problem? The answer would be a simple keygen, wich we don´t have. If you did, would you mind help?
    Regards.
    Member tunahansahiner's Avatar
    Nov 2019
    Hi tehmas,
    I want to ask something to you. We have a Jiten Edm wire cutter machine but it broken when we are running the machine 5 minutes later. on machine interface messagebox says : " over usable time, please input password?" . but we arent unlock this message . Did you solve your EDM machine ? maybe it is a similir problem.
