Hi everyone, i'm new in this world of CNC machines. I'm starting a new project that includes make a CNC plasma table, in this case I select a 4'x4' machine and I already have a few parts that enlist below:
RM1605 1385 mm end machined ballscrews
RM1605 single nut
FF12/FK12 sets
SBR20 1400 mm linear rail
SBR20UU block bearing
Nema 23 stepper motor
162 mm linear shaft
Steppet motor driver micro controller
50W power supply
CNC stepper couplers
16 mm SCUU linear ball bearings
I hope you can help me because I have a few questions about limitswitch, how use the software, how install the THC or what plasma cutter use, however, I will be updating the progress.
Thanks for watching.
I'm no expert but it looks good so far,
You should consider what type of smoke and dust control system you are going with and integrate it in the early design stages. A water tray is cheaper but you might be looking at about 500lbs of weight added to your table, something to consider when sizing your members.
Also, you can use 3:1 or 5:1 gearboxes with your step motors, looks like you show this in your model, you can find these used on ebay. Direct drive may or may not work best i guess it depend on your application.
Neuron THC looks very good, I plan on getting one for my table when its up and running. Neuron CNC
Hypertherm plasma cutter all the way! PM45 is CNC ready too
I'll put on the water tray later, firs I want to learn to use. To install the gearboxes I need to know how the stepper motor works and then put it on or not, this is my first plasma table so I have no experience
Finally I got some stuff and I'm waiting for steel plates for the next week
Screws
Mounting board for the electronics
Torch plates
More torch plates
Cable drag chain, controls, relay and electric fan
Top guard
Bench
try plasmaspider.com that forum has a lot more knowledge on CNC plasma cutters
Hector,
How is your build coming along? Any updates?
Corey
I'm working on the electronics and I'm waiting for the nemma stepper mounts for install it, Also I need to cut the grid slats but I have not found someone to make them on a CNC table
Electronics mounting board
Grid slats
Finally an update, for now, I'm testing the CNC plasma table without the plasma cutter connected, I need to install the torch holder and grid slats to cut some pieces. Also I'm learning how to make better Gcodes in Inkscape. I think that the CNC is slow but it's better than nothing.
If someone has any recommendation to test it or improve it is welcome.
Hector,
I agree that it looks a little slow. While it would probably work, I'd expect rounded corners (from the heat) and probably an additional amount of doss in the cut. Depending on the thickness of your material anyway.
One question. Only because it wouldn't cost too much more, had you though of using gears to add drive speed (at a loss of torque)? There would be additional math involved, but once it was all sorted out, I think you would have more versatility due to the increased speed.
For my first project, I cheated. I purchased a R7 (Router) kit. I'll learn on this and hope to (in the future) use this to build my plasma table.
Corey
This is my very first CNC, I installed the system with screws because it was my first option, I had never seen a machine in person, only in videos. The X axis has two stepper motors connected in parallel and I think that is the reason why I can't increase the speed on Mach3 (up to 40 in/min doesn't work, only X axis), may be if I install another stepper driver, one per motor in X axis, it can be faster.
In the future may be build another with gears, however, for now I will use it just like that to recover some money (4 months of been working on it)
Hector
