If you are looking for both light weight for plasma and rigidity for router did you think about making a two part gantry. Was just thinking you could have a lightweight gantry for plasma and then when you want to use it as a router, roll up the second half of the gantry which could have a second set of bearings running on the same tracks and bolt it to the lightweight gantry to increase rigidity?
