New PICStep firmware available - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: New PICStep firmware available
  1. #13
    Feb 2006
    Thanks..I would prefer to use the drive with out the timeout. There is a disable pin on the servo drives this will be working with that is controlled by a switch on the control panel and by EMC2 which is the controller software I am using. The "Enable(Brake)" pin will be used to "sleep" the entire drive.
    The servo drives run the X and Y axis and this stepper drive will run the Z.
  2. #14
    Sep 2006
    Serbia
    Quote Originally Posted by Garfield2 View Post
    Comment out these lines to reduce the timeout to like 70secs or change "timeout_reg, 2" to some other bit field number (ie. 0-7) to increase the time. Experimentation is the key (else crack out the calculator and use the number of instructions versus the clock frequency to get an exact time)
    -A.
    Thanks, but now I have problem with MPLAB. There is to many errors when I trying to compile. Is it assembler code correct?
  3. #15
    Jun 2006
    Hong Kong
    Seems the no timeout version still haven't fixed yet. Does anyone can modify the timeout (lets say 30mins) with sucess?
  4. #16
    Feb 2006
    I have been using the "stock timeout version" here for some time now and it has worked perfectly and the "timeout" has not been a problem. It all depends on if there is enough "gear reduction" in the axis drive to resist moving with the motors turned off. For me the 3:1 reduction and the magnetic detent in the steppers is enough to lock the axis in place.
    Quote Originally Posted by bearbears View Post
  5. #17
    Jun 2006
    Hong Kong
    Because my milling machine is using direct motor coupling and grounded ballscrews, when the motor sleep those axis will move by the cutting force. As I would like to use the 1/8 microstepping so that the no timeout version can not be used. Anyway, thanks for your tips and reply.
  6. #18
    Aug 2007
    za
    Default PicStep Problem Micro Stepping
    Ok guys i have been using picstep for 3 years now and i have been really happy. Suddenly i wanted to change my micro stepping on the Z drive to get better performance. There is a bug and i have tested over and over why i have no idea but i am working on it . I have compiled the asm file in MPLAB both versions with NO TIME OUT you will NOT be able to micro step period. Only 1 diffrence between the 2 files i cant work out why just yet. Anyone wanting to micro step will have to use the files with 5min time out. I want to get the time out on my Z drive up to about 30 min and when i sort it out i will post. As you all know the time out software you stand a chance of loosing your zero. I guess Alan did not get enough donations from all including myself to sort the problem out considering how many people use his board. So lets be gratefull anyway.
  7. #19
    Aug 2007
    za
    Default PicStep timeout Sorted ;-) for Micro Stepping
    Ok i got it sorted 35min is long enough for me, With permision i will post the hex and asm files due to copyright but here is the line you have to modify
    incf timeout_reg, f ; Increase the timeout reg value
    btfss timeout_reg, 2 ; Check we've been around the 4 times of the 16 bit
    Change timeout_reg, f
    ibtfss timeout_reg, f ; Check we've been around the a lot more times
    timeout_reg, f (f) gave me a time out of 35 min and that is fine with me i hope this helps you guys. Have fun & happy CNC lol i mean Xmas lol
  8. #20
    Registered Garfield2's Avatar
    Sep 2004
    Quote Originally Posted by dalescnc View Post
    I've gotten a few donations from people (thanks! you know who you are), but I got a lot more nasty people who'd rather be demanding and unappreciative than civil.
    Makes giving stuff away for the love of it a little hard.
    -A.
    P.S. I'll patch the files on fromorbit.com soon. The PICStep page really needs an update.
