Build Thread Sense Step on Stepper ?
Results 1 to 5 of 5
Thread: Sense Step on Stepper ?
    Apr 2015
    Default Sense Step on Stepper ?
    I wonder if its possible to sense each step on a stepper by monitoring the back emf of the un-energized windings or the backemf. This would allow for the calculation and compensation of lost steps by using a pick or arduino.
    Registered hub's Avatar
    Sep 2010
    Finland
    Default Re: Sense Step on Stepper ?
    Connecting an encoder would be more simple & accurate.
    :) Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Apr 2015
    It would be but was more thinking about doing it at the controller end with no additional hardware. was really just a thought after reading about someone doing something similar with a brushless DC motor.
    Driving A Brushless DC Motor Sloooooooowly | Hackaday
    Sep 2010
    Finland
    What controller do you have? Custom Arduino? You could connect the encoder to ard. (+ some programming).
    Apr 2015
    i have a few, nano, duo and uno. it was really just a brain fart after reading that article.
    My other project is at the moment still underway but has stalled due to me not having the experience to add what I need to GRBL for sensing the switch, incramenting the counter and adding the custom M code that gets sent from the software. :/ May put another post up about it.
