Vcarvepro drawing problem
Results 1 to 3 of 3
Thread: Vcarvepro drawing problem
    Gold Member Mr.Chips's Avatar
    Sep 2003
    Gilbert Az
    Default Vcarvepro drawing problem
    Frequently I will make a drawing in VCP using circles an squares and combine them, cutting only the parts I don’t need.
    I set the cut to be outside and when previewed some of the cuts are inside and some outside.
    And when I select “ join vectors “ it can say 5 open vectors but the “join” command is grayed out.
    How can I correct this.
    In the past I have just given up and went outside of VCP and drew it then import it. I would really like to use VCP TO MSKE THE DRAWINGS WITH.
    THANKS
    Member routalot's Avatar
    Dec 2003
    Default Re: Vcarvepro drawing problem
    Are you using the Vector Validator option to locate the problem areas?If they won't join its probably an indication that the entities are located in such a way that you are asking them to do the impossible.I can't remember if there is a tangent snap option in Vcarve.If not you may need to draw the straight lines in their desired location and then use the fillet option to create the radii as this ensures the entities are in contact and I believe it also joins all three entities (the two lines and the radius).If you try to cut an outline that isn't joined,the machine is likely to behave in the manner you describe as it may default to left or right of the vector and will define that side from the order of creating the endpoints.
    Member ZASto's Avatar
    Apr 2005
    Vanuatu
    Can you share the drawing, after cutting extra parts?
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
