- Change a group of hole diameters from one dia to another
Gold Member
Mach 3. VcarvePro 8.5
I have defined a large number of hole diameters and depths, now I need to cut a smaller diameter and dirrerent depth for the same large number of holes. It’s a stepped hole, upper dia. ID 0.400”, 0.300” deep, then a dia. of 0.200” all the way through 0.750”
Is there a way to accomplish that In VCP?
Reason: Add detail
- You may not post replies
- You may not edit your posts
Forum Rules
