FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD
Results 1 to 2 of 2
Thread: FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD
    May 2018
    Default FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD
    Question. What are the control circuit connectors used on these VFD's called? I think the pin spacing is 2.4 or 2.54 mm. I bought this VFD from Surplus Center and it came without the screw terminal connectors.FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD-connectors2-jpgFUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD-connectors-jpgFUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD-connectors-jpg
    Attached Thumbnails Attached Thumbnails FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD-connectors2-jpg   FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD-connectors-jpg
    May 2018
    Default Re: FUJI FRN0.75C1S-7QI 240 VAC 1PH to 3PH VFD
    Could not get much info from Surplus Center. I finally found someone at FUJI that told me that these VFDs were programed for a specific machine and were not able to be used otherwise. All I could get it to do was power up, but could not change any settings and could not get power out to the motor. Sent them back and got a refund.
