- Freqrol A500
Freqrol A500
I am working on a machine equipped with a Mitsubishi Freqrol A500. There is not an encoder on the spindle or the motor. The A500 also does not have the accessory encoder board. Does anyone know if there is a parameter that can be set to be able hold the spindle stationary. Something like a spindle orienting command that would be used if the spindle had an encoder.
Thanks to all,
CNCJEFF1
- Freqrol A500
- You may not post replies
- You may not edit your posts
Forum Rules
