how to use vfd for old cnc mill - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 101 to 110 of 110
Thread: how to use vfd for old cnc mill
  1. #101
    Apr 2012
    Default Re: how to use vfd for old cnc mill
    ok, no worries, so i just need to run a wire from fwd&rev down to the contactor or relay and then on the other side of that relay take a wire back to the GND (common) pin of the VFD.
  2. #102
    Dec 2013
    Yup, that's all there is to it.
    Jim Dawson
    Sandy, Oregon, USA
  3. #103
    Jan 2005
    Quote Originally Posted by jaysihn View Post
    No that is not correct you could not use the contactor to switch this it would be to harsh
    And for the wiring the Relay basically is just a switch ( 1 ) side you connect to FWD the other Side to DCM and the same for the Reverse it is best to use a solid state Relay then you won't have any noise with the switching to worry about
    Mactec54
  4. #104
    Jan 2005
    so put 10V output from the VFD to one side of the contactor and then the other side of a contactor back to teh fwd or rev pin of the vfd? I wasn't as comfortable with that just because there are still a variety of other wires going to those contactors that i didn't want to risk screwing up. I figured a couple of DC/DC relays would be safer and cleaner.
    Any reason not to use the dc/dc relay option if I want to?
    No you should not be using the 10v output from the VFD Drive for anything other than to supply for a PWM to analog Breakout board 0-10v supply
    2 Relays is all you need that are controlled by M3 M4
    Mactec54
  5. #105
    Member machinehop5's Avatar
    Aug 2009
    so i did some digging to find the wires that correspond to spindle fwd and spindle rev coming from the cnc controller. i found pins 61 and 64 which seem to be 24V logic pins. they go into some relays which have 120V output that feed the main contactors..
    ...these relays look like Solid State Relays (SSR) already installed from factory. photos worth a thousand words
    how to use vfd for old cnc mill-ssr-lagun-250-jpg
  6. #106
    Dec 2003
    Quote Originally Posted by machinehop5 View Post
    Opto22 I/O modules, AC output, maybe.
    Aug 2009
    Quote Originally Posted by Al_The_Man View Post
    ...bingo. I think you nailed it. http://documents.opto22.com/0510_Std...data_sheet.pdf
  8. #108
    Apr 2012
    Ya those are ac output. They have 20 something vdc on one side and 120v ac on the other side. I wired it up with the contactors as the switches to pull the fwd and rev pins to the gnd/common of the vfd. Works perfectly at this point...
  9. #109
    Dec 2013
    Sounds like you're making progress.
    Jim Dawson
    Sandy, Oregon, USA
  10. #110
    Aug 2009
    ...its all jaysihn's default for saving the Lagun250....
