HY VFD to control ssr's
Results 1 to 7 of 7
Thread: HY VFD to control ssr's
    Oct 2005
    Default HY VFD to control ssr's
    I'm just getting ready to use a HY vfd and I want to control a couple of ssr's to control the water pump and a vacuum.
    Haven't even powered on the VFD yet but I wanna get the wiring done.
    So I wondering the best way to connect the ssr's.
    Is the VFD 24v output "always on" or is it on with the spindle?
    Figuring if it's on with spindle I'll just use that.
    If not, is the relay on with spindle? transistor on with spindle?
    Basically looking for anything that is on with the spindle and not always on/
    thanks.
    Dec 2013
    Default Re: HY VFD to control ssr's
    There a normally a couple of programmable outputs, normally one relay and one transistor. The relay should have both NO and NC contacts. You can program them for any available function.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    You could use either Up To Speed, or At Zero Speed, if the latter then you use the N.C. contact on the relay and this should be open at zero and close as soon as the spindle starts.
    Jan 2005
    Quote Originally Posted by frunple View Post
    thanks.
    You have 3 to choose from FA FB FC they are controlled by PD052 which needs to be set to 01 this will turn on when the VFD Drive is turned on from or by the control Terminals FWD and DCM
    Mactec54
    Dec 2003
    On an allied note, I have also used an output fed back to the controller for spindle Up-To-Speed signal, in order that no move takes place until the spindle has reached the programmed spreed.
    This would be the output set to 05 - Set frequency.
    One of the transistor open collector PLC outputs can be used for this.
    Oct 2005
    Quote Originally Posted by Al_The_Man View Post
    That's a great idea.
    What controller do you use?
    How did you tell it not move? Is it looking for a voltage?
  7. #7
    Dec 2003
    Actually it was a Galil motion Card using Galil HMI program/interface I adopted, what I did was issue a RPM, Sxxx to the spindle, and used the FIN(ish) signal method used in CNC/PLC programming.
    This is where a CNC program waits for the FIN signal confirmation back to an input before continuing to the next command rung.
    It may be possible to implement in other controllers where this type of command is used.
    There are a few other examples of this, such as where a chuck close pressure switch has to be seen before the program continues etc.
