If nobody replies, remind me in about 12 hours and I'll measure mine tonight.
Hi, i am looking for the dimensions of the above for a 2.2KW. Can anyone please assist, tried but not ale to find this in any manuals i looked at?
Erick
- Need Help!- HUANYANG INVERTER AND SPINDLE SET UP
- Need Help!- huanyang inverter HY020223B 3hp 2.2kw
- Need Help!- 220V in to Huanyang Inverter
- huanyang inverter burn
- Need Help!- Huanyang inverter
UCCNC 2017 Screenset
Hi Gerry....can you please get me those sizes when you get a chance?
Erick
Unfortunately, when I went to leave work yesterday, the battery in my truck was dead, which led to a two hour ordeal to get home, followed by an hour to change the battery, make dinner, and go to sleep.
I'll get the info tonight.
No problem, whenever you get a chance
My HY 3KW VFD is 5"wide, 7 inches tall and 6 inches deep. Pretty sure the 2.2 and the 3K are the same size.
Halfnutz
Mactec54
OK, It's about 130mm wide, 170mm tall, and is about 160mm deep from the back plate.
Which is basically the same size as Halfnutz. In inches, I had 5" x 6-3/4" x 6". But I figured that you'd prefer mm's.
Hitachi is another one that is used quite a lot, so if you can fit these, then you should be able to fit anything else that is out there in that power rating of your cabinet
Inches to millimeters is very easy 5" x 25.4=127mm or if you want inches ( not likely ) 127mm / 25.4=5"
Mactec54
Hitachi is okay but i expect it to be above my budget. I found a 2.2KW for $200 AU
