EMI filter for 240v single phase?
Results 1 to 7 of 7
Thread: EMI filter for 240v single phase?
    Jun 2015
    Default EMI filter for 240v single phase?
    I have a potential noob question about EMI filters. I'm about to add a spindle to my CNC Router (currently using an actual 120v router), which will require installation of a VFD. Because of all the EMI issues I've read about in other threads, I'm trying to make sure I ground properly, etc, but I'm running into issues on an EMI filter for the incoming 240v mains. I've looked at most of the EMI filters I see commonly discussed in the threads (e.g. Schaffner FN2060-20-06), as well as those I find when I search for 240v single phase EMI filter, and their wiring diagrams have lugs for L and N on the line side. That would seem suitable for countries where mains are 240v line with a separate neutral, but in the US, 240v circuits are split phase, with L1 and L2 - each with 120v, 180 degrees out of phase between them - and without a neutral line, so I'm not sure if those would work. What EMI filters are others using for 240v setups in North America? FWIW, I'm hooking up a HY04D023B VFD driving a 3.2kw water cooled Chinese spindle.
    Thanks,
    Greg
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: EMI filter for 240v single phase?
    You can use the EMI filter in the US by connecting L1 to the terminal live terminal L and L2 to the neutral terminal N
    EMI filter for 240v single phase?-emi-filter-jpg
    in the UK the neutral supply terminal is connected to the protective earth PE
    depending on when the supply cable was installed the earth & neutral is joined together
    either at the 3 phase transformer star point or the utility company supply terminals
    that's why its call neutral instead of line 2
    one problem with EMI filters is the eath leakage currents due to the capacitors marked Cy on the filter circuit
    some VFD's have a jumper to enable the user disconnect the Cy capacitors from the PE
    to avoid the EMI filter tripping the RCCB / GFI
    John
    Jun 2015
    Thanks for the quick reply, John. Much appreciated!
    I know Schaffner makes a "B" variant of that filter that omits the Y capacitors; I'll have to see if I can easily get one. Although, the circuit this is going to be on isn't GFI protected, so I don't guess it would matter in my case.
    Thanks again!
    Greg
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by good-ham View Post
    Thanks again!
    Greg
    Here is a Power Filter which is a better product and price is good also TDK Lambda RSEN-2030L the L is for low Earth leakage so may not have any affect on your GFI
    Mouser has a good price on these $22 to $25
    967-RSEN-2030L
    Attached Thumbnails Attached Thumbnails EMI filter for 240v single phase?-tdk-lambda-rsen-2030l-power-filter-png
    Mactec54
    Jun 2015
    That looks great. Just ordered. Thanks!
    Member Azalin's Avatar
    Mar 2014
    Turkey
    In my lathe I added something (people recommend it) that always output live and neutral on the same terminals, even if I plug the power plug to the wall inverse or reverse. I'll open the cabinet and see what it was (I'm a noob too).
    By the way, I also use an emi filter for the spindle servo drive on my mill. That particular filters input pins are L1 and L2. If you're interested I can give you the brand and part info.
    Sent from my MI 5s Plus using Tapatalk
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
  7. #7
    Member Iron-Man's Avatar
    Jan 2009
    Thanks,
    Greg
    Good-Ham,
    I have used these with no problems;
    https://www.ebay.com/itm/ALLEN-BRADLEY-2090-UXLF-110-AC-LINE-FILTER-250VAC-10AMP/273072275669?_trkparms=aid%3D555018%26algo%3DPL.SI M%26ao%3D1%26asc%3D57476%26meid%3Dcbd782088709442d af4432b48cbfa961%26pid%3D100005%26rk%3D1%26rkt%3D1 2%26sd%3D182050275393%26itm%3D273072275669%26pg%3D 2047675&_trksid=p2047675.c100005.m1851
    If you search on Ebay sometimes you can get them brand new for around $ 25.00.
    Hope this helps,
    Iron-Man
