Bridgeport cnc mill spindle slows and stops when taking a cut
Results 1 to 1 of 1
Thread: Bridgeport cnc mill spindle slows and stops when taking a cut
    *Registered User* Bobsgto's Avatar
    Nov 2018
    Default Bridgeport cnc mill spindle slows and stops when taking a cut
    Hi all,
    looking for some help with a bridgeport cnc mill that has a mitsubishi vfd d700 inverter. the spindle slows and then stops when i start taking a cut with a 2" face mill .060" depth of cut. barely gets into the cut then stops. i tried changing some parameters in the vfd with no success. any help would be greatly appreciated!
    Dec 2013
    Default Re: Bridgeport cnc mill spindle slows and stops when taking a cut
    Is this a new VFD install, or something that just started happening after running OK for some time?
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2018
    it's a new VFD install.
    Dec 2013
    I took a quick look at what I think is the manual for your VFD. It looks like you need, at a minimum, to set parameters 80, 82, 83, and 84 to the motor nameplate specs.
    Jim Dawson
    Sandy, Oregon, USA
