Need Help! Phase converter for a machine with several load changes: rotary or digital? - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: Phase converter for a machine with several load changes: rotary or digital?
  1. #13
    Gold Member
    Jan 2005
    Default Re: Phase converter for a machine with several load changes: rotary or digital?
    Quote Originally Posted by Ale88 View Post
    In another forum I got this answer, what do you guys think?
    Rotarys going back at least 50 years have been doing the job and handling changing loads without problems.
    Contrary to salesman representations, digitals do NOT respond well to load changes. There are many references to this situation on machine tool sites, including the need to employ multiple digital converters on machines with multiple motor loads.
    The representation "the digital phase converters work just fine with multiple loads" is called puffery in polite terms when it comes from a salesman's mouth. Working just fine with a multiple load may be true under some circumstances, but it is not saying works fine with a multiple load that changes during the machine's use cycle.
    Your gelato machine has 2 very different loads on the mixer alone, evidently caused by different requirements to stir when mixing and then freezing. In addition your refrigeration compressor will be starting and stopping as well as probably absorbing an inconsistent amp draw during the chill period.
    That all adds up to a lot of load changes to the converter on every batch.
    A rotary easily compensates for load changes through momentum and additional draw on the single phase side.
    Solid state lacks the momentum feature so a computer must sense load and adjust electronics to accommodate it.
    If the frequency of output power MUST be maintained, solid state might be worth considering, but in your case it isn't a consideration, your loads are 100% motor.
    Your suggestion a solid state converter is quieter indicates you haven't had the opportunity to spend time around one. They emit everything from ultrasonic down to a whistle and generally drive dogs away.
    Were I in your position I'd buy track record and that is rotary.
    If you opt to go solid state insist on a written guarantee of fitness to the purpose of running your machine in your environment signed by a company officer and backed by a third party bond.
    I'm always Amazed the things people post on these forums, most have not experience what's so ever with a Phase Perfect but still talk a load of BS about them
    With noise the only noise there is comes from the 2 fans that's for air circulation and only run automatically as needed for cooling
    They are not using a Phase Perfect then it they have any of these problems you list in your post
    Mactec54
  2. #14
    *Registered User* Ale88's Avatar
    Oct 2018
    So in your opinion I could place the PP panel in a part of the shop with people passing by? It doesn't really bother the noise? Because I have to think also on the customer's side.
  3. #15
    Gold Member
    Jan 2005
    How much noise does the machine make this may be more than you will hear from the PP, I have mine mounted under the stairs there is a very low electrical noise that comes from the unit when the fans are not running, but being under the stairs you can't here that noise outside only the fans when they turn on and if nothing else is running in the shop, with my Haas mill turned on you can't hear the PP at all, the fans in the Haas electrical cabinet make more noise than the Phase Perfect, I know a Doctor that is using 2 of the largest PP to run a Imaging unit because they did not have 3Ph power in there building
    I had another though about your setup and most likely you could use 3 VFD Drives ( 1 ) for each motor this would be the cheapest way to do this and would cost no more than $2000 for 3 of the best VFD Drives money could buy, the rest of the control would be running on single phase so this would take care of the 3 ph part and the VFD Drives will run on the 240v single phase supply you have
    I would do it this way if the machine control can be configured to turn the VFD Drives ON/OFF because your motors are most likely set at one speed the VFD Drives can be controlled with just a relay to turn them ON / OFF
    Your machine may already have a VFD Drive of some kind in it, if so this can run on the 240v Single Phase supply you already have
    Mactec54
  4. #16
    Oct 2018
    I don't know about that, I asked to the manufacturer and they told me they only use phase converters to run the machines when they don't have the 3 phase, and to be honest I don't wanna take any risk, it costed me a lot of money that machine, I prefer paying a few hundreds dollars more and being 100% sure it'll work.
  5. #17
    Gold Member
    Jan 2005
    You are only running 3 electric motors this is the most inexpensive way to do it, the easy way is of course to buy the phase converter either way would work adding the VFD Drives would take someone that knows how to plain out the wiring this is very doable and would work just as well as any phase converter
    Your main motor if the speed is variable and is a regular AC Motor then it will already have a VFD Drive so you would only need ( 2 ) max $700 plus some rewiring, ask the manufacture what they are using for motor control
    Mactec54
