- Huan Yang GT-5R5G-2
Huan Yang GT-5R5G-2
Hi, new to this forum. A few months ago I burn out my Huan Yang vfd model HY02D223B so as a replacement I got me a Huan Yang vector type inverter model GT-5R5G-2 in trying to hook it up to my 22 kw air cooled spindle I toasted the spindle,again I had to get a new spindle this time I went bigger I got a 3.5kw square air cooled 220v 300hz this is the reason I candidly ask for all the help in setting up the right parameters for this GT-5R5G-2 inverter also I am using mach3 software, before I burn out the vfd I was using RS485 to control the speed. The more I read the inverter manual the more scared I become. I am in deep …… I need all the help that you can provide. Again thank you in advance.
- You may not post replies
- You may not edit your posts
Forum Rules
