- LCD panel does'nt display
Hi guys,
I'm from Cameroon, and I own a 900x1200 chinese cnc router that works quite well.
I've been warned by the builder to work at 6,000 rpm but the spindle speed is programmed at 10,000 rpm in the inverter.
When I laucnhed a work at 10,000 rpm, the machine stopped some minutes after and since, I can't start the spindle, and the inverter display is off. Can you tell me how to fix that issue ?
HEEEEEEEEEELP !
- You may not post replies
- You may not edit your posts
Forum Rules
