Need Help! New VFD and spindle motor, RPM too low
Results 1 to 10 of 10
Thread: New VFD and spindle motor, RPM too low
    Dec 2016
    Estonia
    Default New VFD and spindle motor, RPM too low
    Hello,
    We bought a spindle motor and VFD from ebay - zero previous experience with such things.
    https://www.ebay.co.uk/itm/112622600823#rwid
    We completed the wiring, VFD and motor both work
    Problem is that motors RPM is way too low and the VFD shows only max 60 HZ when running. The speed can be adjusted only between 0 and 60.
    The manual is too confusing for us and we can not understand which factory settings need to be changed.
    Only thing we could think of is to change most 400s to 300s with no luck.
    Most similar manual to ours I could find online:
    http://www.frequency-converter-china...2143083921.pdf
    Any tips that could help us forward are greatly appreciated.
    Many thanks ahead,
    phootsman
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: New VFD and spindle motor, RPM too low
    Don't try to run it again until you have the proper settings, or you'll damage the spindle.
    The seller doesn't have a manual?
    UCCNC 2017 Screenset
    Dec 2016
    Estonia
    Quote Originally Posted by ger21 View Post
    We do have a manual. The Parameters Function List/programming part seems to be 100% the same as the linked manual. But we have no idea which settings to change.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by phootsman View Post
    Hello,
    Many thanks ahead,
    phootsman
    I will do a list of Parameters you need for your VFD what I had posted was for a HY VFD
    Mactec54
    Jan 2005
    Hello,
    Many thanks ahead,
    phootsman
    Some advice for buyers, when you see advertised imported German Bearings, don't buy from this seller, the German Bearing they use a manufactured in China
    Always Buy a VFD with a common Brand name not some look alike, like this one is this looks like the popular Huangang VFD Drive, don't be fooled by look a likes or copies
    Here is a rough list of what Parameters you need to set
    P00.00=300
    P00.04=300
    P00.05=300
    P00.06=100
    P00.09=200 ( adjustable for you Spindle Minimum Speed, Keep it safe nothing below 100 )
    P01.04=100
    P0.600=10
    P0.700=300
    P12.00=12
    P12.01=220
    P12.02=2
    P12.05= ?? ( Your VFD Drive Max Amps Output )
    Mactec54
    Dec 2016
    Estonia
    P00.00=300
    P00.04=300
    P00.05=300
    P00.06=100
    P01.04=100
    P0.600=10
    P0.700=300
    P12.00=12
    P12.01=220
    P12.02=2
    P00.09 - factory settings were 0,2. Set it to 200, the motor stopped working
    P0.006 - did you mean 00.06? 00.06 can only be set between 0 and 1
    Went over the manual again and changed P07.08 (Frequency source selection 1). Finally got the speed needed.
    Problem now is that the speed adjustment knob does not do anything.
  7. #7
    Jan 2005
    Below is P00.06 and P00.09 both should be 100
    Try this
    P00.01=0
    P03.08=0
    P03.09=300
    P07.08=0 This can't be 1 if you want to use speed adjustment knob
    Attached Thumbnails Attached Thumbnails New VFD and spindle motor, RPM too low-p00-parameters-jpg
    Mactec54
  8. #8
    Dec 2016
    Estonia
    Try this
    P00.01=0
    P03.08=0
    P03.09=400
    Sorry. I meant 06.00. You wrote "P0.600=10" and I assume you meant 06.00 , Acceleration Time. This can only be set 0-1
    The ones below should be aleady set as you suggest because they are factory defaults.. Can't check the machine now but per manual those are defaults
    P00.01=0
    P03.08=0
    P03.09=400
  9. #9
    Jan 2005
    P00.01=0
    P03.08=0
    P03.09=400
    It should of been P06.01=2 not P06.00 my mistake
    P06.01=2 Default is 2 you may need this higher for these Spindles this is the acceleration time
    P06.02=2 Default is 2 also this may need to be higher, this is Deceleration Time
    P03.08=0
    P03.09=300 This to is not the Default and needs to be set also, this is for the maximum Spindle speed
    P03.09 I posted this as 400 but that is incorrect for your Spindle
    Mactec54
  10. #10
    Dec 2016
    Estonia
    P03.08=0
    A million thanks!!! Now everything works as it should. At least it seems to.
    I even started to understand what all these things mean.
    Can not thank you enough, mactec54!!!
