I just notice that the incoming voltage varies between 233 to 245 here.
I’m having a hard time trying to balance the voltage in load. There is one thing for sure, the extra 74 uf I added on the capacitor starter makes a big difference. The 10 hp has no problem to start and the breaker does not open at all.
I’m lost a bit with the voltage balance.
Before I start the 10 hp, L1-L2 is 240 volts
After I start the 10 hp, T1-T2 is 238, T1-T3 248 and T2-T3 262 volts.
Where should I add or remove capacitors?
