Need Help! hy01d523b Wiring Diagram
Results 1 to 6 of 6
Thread: hy01d523b Wiring Diagram
    May 2013
    Smile hy01d523b Wiring Diagram
    Hey all,
    I just bought a new cnc machine and this one came with a hy01d523b but no real instructions how to wire up the Active Neutral and Earth ? all other wires have tags on them to indicate how to wire up but not the power ?
    I really dont want to blow this up on the first day
    May 2013
    hy01d523b Wiring Diagram-img_20130519_125745-jpg
    Dec 2003
    If single phase input , 1 & 2 are live and neutral and 9 earth ground.
    UVW is 3 ph to the motor.
    May 2013
    Thank you , it's now working
    Feb 2007
    mexico
    Default Re: hy01d523b Wiring Diagram
    if two phase input? live live & neutral?
    Dec 2003
    Quote Originally Posted by jpgmoreno View Post
    You do NOT use neutral if you have L1 & L2 which is single phase, BTW.
