- Newbie- Can FlatCAM engrave a simple path
Re: Can FlatCAM engrave a simple path
Funnily enough, others seem to have asked the same question and apparently the answer is "yes, but only the stupid way - by using the command line". See this: https://caram.cl/software/flatcam/tr...-with-flatcam/
Fair warning, Flatcam 8.5 just threw an error on that for me - YMMV, or you might just need the exact version used in the linked post (v7). Good luck...
- You may not post replies
- You may not edit your posts
Forum Rules
