- Hi All I am new to cnc.
Hi All
I am kees, coming from holland, I was here before but can not log in anymore, so made a new membership.
I do electronics so I did build a cnc for that, it is not yet ready so I need to have some info about the lineair rails from thk.
I have for the task of pcb milling a little to heavy slider rails and even bigger slider blocks. These can fit a mill who can do steel so heavy the are.
I want to ask if I can use just two silder blocks for this heavy rails, she are quite big and strong, when I use just two I have more plot area.
dimensions of these are 58 x 70 mm, for me I think two rails and two carriers are enough.
I like advice,and it is only for pcb milling, machine is made from high densitiy waterresistant woodfibre/mdf, really stif made, this is only because i want to see what it does and if i like it, then I can go maybe to aluminium system.
Electronics like the drivers and processor boards I make myselfs.
regards.
Re: Hi All I am new to cnc.
- You may not post replies
- You may not edit your posts
Forum Rules
