- Just In Make PCBs using a mini CNC Router under $200!
Hi everyone, I have did some research to find a cheap CNC router to make prototype PCBs and I have came across this one: https://amzn.to/2G9NQjX. So I have bought one, not expecting much and the result were very good, clean circuit boards. I've got the traces as thin as 0.6 mm. I have made a YouTube video showing the process of make a PCB using this machine. I also have the parts I have used and the software in the description. I am currently editing the second part of the video where I apply a UV solder mask to protect the circuit.
Here is the link to my YouTube channel/video: https://bit.ly/2XupKuW
If you guys want a tutorial video, then like the video and comment in the description of the video for a tutorial.
Be sure to like and subscribe for more videos to come!
Here are a few pictures of the PCB with and without UV solder mask that is in the video.
- You may not post replies
- You may not edit your posts
Forum Rules
