Need Help! [Math]Calculating offset for v-groove, using bit ° and cutting depth.
Results 1 to 6 of 6
Thread: [Math]Calculating offset for v-groove, using bit ° and cutting depth.
    Activation process LittleRain's Avatar
    Jan 2019
    Default [Math]Calculating offset for v-groove, using bit ° and cutting depth.
    Sorry if this is the wrong place to post this.
    This is what I'm trying to find out, you don't need to read the rest of my post if you look at this.
    What I have is a panel of circuit boards. I start with a 2d contour operation around each board, and leaving some tabs.
    Then I would like to v-score all the tabs from the top and bottom, but the problem is fusion is not calculating the proper offset for me.
    After some help on the autodesk forums, I almost have the correct offset, but realized I won't be able to do exactly what I want, without manually creating the tool path, using a sketch and some math(This is where you come in).
    Before I had help, my 2d contour was basically just tracing because of the chamfer bit.
    After I had help, you can see that the offset is correct, but only when I want to cut all the way to the bottom.
    This is the same operation, but at 1/4 depth. As you can see its not in the correct place.
    This is what I would like to achieve.
    Nov 2012
    Romania
    Default Re: [Math]Calculating offset for v-groove, using bit ° and cutting depth.
    The distance your tool axis needs to be from the edge of the PCB for a given depth of cut D is made up of two parts: obviously, half of width of the flat tip, plus whatever the "O" side of triangle formed by the lines A, O, and the edge of the PCB amounts to. Being a right angled triangle, that horizontal side is related to the vertical side (which is equal to the depth of cut D) through the tangent function. Half of the 0.1mm flat tip is simply 0.05mm.
    Therefore, for a depth of cut "D", to touch the edge of the PCB your offset needs to be O = D / tan(60) + 0.1 / 2; numerically substituting 1/tan(60) with its approximate value 0.57735, that becomes O = D * 0.57735 + 0.05; for the example of D = 0.6075, that works out to be O = 0.40074mm. Good luck...!
    Jan 2019
    Bravo! Amazing stuff! Man math is awesome stuff, may I ask how you know the answer?
    Did you go to school/were taught it, or did you figure it out on paper/in your head?
    Nov 2012
    Romania
    We did learn enough trigonometry way back in school to leave (after all that I've forgotten) just enough in my head to do fairly simple stuff like this... Glad if it helped.
    Jan 2019
    It helped me greatly, thanks again!
    Unfortunately I left high school before I even got to a class that taught trig or calculus, I'm gunna have to start learning online.
    Member lwill's Avatar
    Aug 2005
    A good tutorial. Look under Cutting Width tab.
    https://www.precisebits.com/tutorials/pcb_mech_etch.htm
