Spindle speed 7000rpm ok?
Results 1 to 13 of 13
Thread: Spindle speed 7000rpm ok?
    Mar 2012
    UK
    Default Spindle speed 7000rpm ok?
    Will 7000rpm for spindle suffice for isolation milling / drilling / routing of PCB's?
    I have 400W spindle, it used to run @ 9000rpm but its power supply(48VDC) blew off and now I'm running at 36VDC and its running at around 7000rpm.
    I have heard that PCB drilling needs high rpms aronud 24K and above.
    I have some 30deg V bits, a few end mills and som drill bits.
    I plan to mill with the 30deg V and drill 0.8mm holes.
    What problems can I expect with doing the above operations @ 7000rpm. Broken drill bits?
    Would I need to modify the feed rate and plunge rate accordingly?
    Any suggestions would be appreciated!
    TIA
    Apr 2013
    Sweden
    Default Re: Spindle speed 7000rpm ok?
    Quote Originally Posted by ZeroBacklash View Post
    Anything is possible, as long as you accept painfully slow speed.
    The problem is that the slower the RPM the less is the torque, so in your case, I'd get a new 48V supply, or connect a 12V in series with the 36V to get maximum RPM. Perhaps you can find a 12V supply in your drawer...? Just make sure it has enough power.
    I run my 24k spindle at 22k to reduce noise and I don't think it would make much difference if I'd run it at 24k.
    TIA
    I am also using 30deg V bits and some drill bits made for PCB. You have to experiment optimal mill speed and plunge depth/speed. Yes, expect breaking V bits and drills until you get the feel. It is impossible to give good advice regarding speeds without knowing more about your machine. Milling speed depends on many other things, not only RPM. Yes, you should definitely modify your speeds, the reduction from 9k RPM to 7k is significant. Be careful when drilling, don't go too fast. On the other hand, if you go too slow, you'll burn the PCB and the drill...
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
    Mar 2012
    UK
    Quote Originally Posted by A_Camera View Post
    Many Many Thanks!
    This is some pretty amazing information. I like the way you do multi pass milling, never thought about it before.
    How do you generate the multpasses does your gcode plugin do it for you or you just pause the program and run the whole thing again?
    Well lots of questions!
    1. How did you get your table absolutely level for accurate milling? I have been trying to use Autoleveller.
    2. How do you fix your pcb's to the table do you use double sided tape?
    3. What kind of clearances do you use when you design the PCB suitable for Isolation milling. I mean the width of traces and distance between traces?
    Have some 12V, 5A spare power supplies, but I guess that won't be sufficient power will probably have to use a PC ATX power supply and take 12V for those, I guess that are meant for high power.
    One again Many Thanks! Truly appreciate it!!
    Apr 2013
    Sweden
    Many Many Thanks!
    The second pass is easy. Once you have the G-code for the first pass you just copy the text and change the parts you want to change, like feed rate and milling depth. The G-code is text, so it is easy to create the multipass milling file.
    4. Have some 12V, 5A spare power supplies, but I guess that won't be sufficient power will probably have to use a PC ATX power supply and take 12V for those, I guess that are meant for high power.
    1. This did take some time, I levelled and squared the machine as well as I could when I built it. I also have a separate waste board fixed in a vice, which I surface mill before starting on a PCB to remove all unevenness as a result of drilling through previous PCB. I don't use any auto leveller, in my opinion that's not necessary if you level your table and use high quality PCB.
    2. Using only painters tape. I am not using double sided tape because it is not flat enough and the PCB is flexing slightly because of the thick tape.
    3. Sorry, I don't remember now. Anyway, I use as little as possible, or as large as necessary. The minimum clearance also depends on your machine and the bits you are using. In the example video, the depth is 0.07mm, so calculating that based on the 30 degree V bit gives 0.04mm. Note that this is calculated and is only in theory. In reality, it depends on how pointy your V bit is, because the Z zero is measured from the real tip of the V bit, which is never as pointy as this calculation. Never the less, if I see that the V bit is too flat or extreme accuracy is needed it should be taken into the calculation as well, or the bit must be changed. I think my bits have 0.1mm tips, so by taking that into account the separation is 0.14mm, which is more than enough for a normal PCB. There are plenty online calculators in case you are not familiar with triangle calculations, you can use this one, as an example if you want to calculate using your own values.
    4. You can always try. You motor doesn't really require all the power for this purpose, unless you stall the motor, so 12V 5A should be enough to "fill up" the needs. Worst that can happen is that the 12V PSU gets hot and the voltage drops, if you feel uncomfortable you can switch it off. The 400W motor is 400W from 48V, and that is 8.3 A, not that far from 5A, but again, the 400W is the maximum and I don't think you'll ever come close to that in this application.
    Member CitizenOfDreams's Avatar
    Nov 2012
    As a rule, it is not a good idea to connect two random power supplies in series. At least when we are talking about hundreds of watts.
    Milling and drilling PCBs at 7000RPM is perfectly doable, just reduce your feed/plunge rate accordingly and make yourself more coffee to drink while you are waiting.
    Mar 2012
    UK
    Thanks for the amazing suggestions A_Camera and Citizen of Dreams.
    I did a run of a test pcb with Autoleveler and then milling it.
    Twice the machine lost track of where it was and while the gcode view was showing some other position the machine was at some other co-ordinates. I later discovered that the Y axis coupler was loose and not driving the Y axis ball screw as required. But I'm not sure this problem is related to the one of the machine losing track.
    Am attaching a picture of the unfinished job.
    Spindle speed 7000rpm ok?-pcb-jpg
  7. #7
    Nov 2012
    Seems like you did not cut through the copper in a couple of places. Can you show us a picture with the dust blown off?
  8. #8
    Mar 2012
    UK
    Quote Originally Posted by CitizenOfDreams View Post
    Somehow the dust seems to be embedded into the PCB, I tried cleaning with a soft brush but the dust isn't coming off. Probably will need some water to get it off?
  9. #9
    Nov 2012
    I usually spray some soft solvent (such as brake cleaner or flux remover) on the board. That both cleans the dust AND lets you clearly see all the traces (while the board is still wet).
  10. #10
    Nov 2013
    I use a VFD and an asynchronous 24000 rpm spindle. I use 0.5mm endmills. When running at 24000 rpm at 1% feed per tooth per rev that works out
    to a federate of 400 mm/min. I halve that to 200mm/min plunge. I personally find the two flute endmills cut very much more cleanly than any engraving
    bit I have tried. In the first instance I used endmills because I have some VERY thick copper board (420um or 12 oz!) PCB and angled engraving
    bit just weren't going to do a good job in such thick copper. The minimum trace width was 0.4mm, so an angled cut would have been very poor.
    The results were so good that I have started using the tiny endmills on ordinary 1oz board as well. I get about 4-5 hours good clean cut with little
    or no burring per tool.
    https://www.ebay.com/itm/10-0-50mm-0...cAAOSwjjpbC1Xa
    If I slowed it down to 7000 rpm with the same chipload the feed rate would be down to 116mm/min and 58mm/min plunge....too slow for me.
    I use Autoleveller with very good results. My typical cut depth is 0.06mm (0.035mm copper) and get perfect isolation every time. I use double
    sided tape to hold the PCB blank down. I try to make the minimum cut depth I can and still achieve isolation. The less fiber glass in the chip stream
    the better the tool lasts.
    I've also found that my endmills last VASTLY LONGER if I use flood cooling. As a consequence I put some duct tape around the edge of the PCB blank
    to try to exclude the coolant from getting between the PCB blank and the spoil board and have the double sided tape adhesive fail before the board is complete.
    I use Eagle to design the boards and then use the U(ser)L(anguage)P(rogram) 'pcb-gcode' to generate the Gcode. It allow multiple passes. For example I specify
    I want 2mm isolation with a 0.2mm stepover the Gcode will have multiple passes (0.5+ 7 x0.2=8 passes) until the 2mm isolation is achieved.
    Craig
  11. #11
    Mar 2012
    UK
    Thats a good idea will try that asap!
  12. #12
    Nov 2012
    Unfortunately, 0.5mm end mills don't cut it (pun intended) for many electronic components. Even the old-as-dirt SOT package has 0.4mm between the pads; SOP needs 0.25mm or better. You can certainly do DIP chips, but without the ability to pass a trace between the pins.
    I personally use V-tip cutters with the effective width of 0.15mm or so. I set the cut width in CamBam (my CAD/CAM of choice) to 1mm so it makes multiple passes where needed. Then, if I want to, I remove the rest of the copper with a 1mm end mill. PreciseBits makes special "copper rubout" cutters just for that purpose: https://www.precisebits.com/products...bit-rubout.asp
  13. #13
    Nov 2013
    I chose 0.5mm because it was adequate for SOIC packages (0.6mm between pads) and SOT89's say but you are right for SOT23's etc I use
    pointy engraving bits. I have made boards quite successfully using TSSOP ICs, (0.2mm between pads) using engraving bits.
    I can squeeze a trace between the legs of a DIP IC (with 0.5mm)....just....and I have to reduce the trace width through the gap down to 0.2mm, doable but
    not ideal.
    The smallest endmill I have used is 0.4mm. They are very tender and I broke a few before I got the hang of it. I then got a whole bunch (30) of the
    Tycom 0.5mm endmills for only $2.65 USD each. I have got the method down pretty good now and so perhaps the next time I get some more micro tools from Drillman
    I might try some 0.3mm's or 0.2mm's
    Certainly the 0.5mm tools last long enough and give a really good finish cut that I consider it to be worth the extra care/cost. If I require finer features
    (less than 0.6) the engraving bits work OK. I suspect that the extra care/cost of 0.2mm endmills say is probably not worth it.
    Craig
