Newbie 1/8" tool in 3mm ER11
Results 1 to 3 of 3
Thread: 1/8" tool in 3mm ER11
    Registered jimthurgood's Avatar
    Jan 2017
    Quietways
    Default 1/8" tool in 3mm ER11
    Would you expect a 1/8" tool in a 3mm ER11 chuck to be OK?
    With the chuck lightly tightened the tool is straight, but when fully tightened the tool tip wobbles. Am I tightening it too much or is it the size which is the problem?
    [Edit] Or is the chuck faulty?
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: 1/8" tool in 3mm ER11
    No....
    the shank is larger than designed for the collet bore,
    - unless the shank goes thru the entire collet bore, the outside collet taper will NOT match the holder's inner taper....this shows up as runout of the tool
    ER collets can only clamp on the range they are specified for,..... ideally, it is best to use the upper collet size, matched to the tool shank size
    ---- for a 1/8" shank, get a 1/8" ( or a 3.5mm ) collet..... it will run true when clean & clamped
    Jan 2017
    Quietways
    OK, thanks. At least the cure is simple if not desperately cheap!
