Request for foam-cutting bids
Results 1 to 2 of 2
Thread: Request for foam-cutting bids
    Dec 2004
    Default Request for foam-cutting bids
    Hi everybody,
    I'm doing the 3D work for someone who is prototyping an aircraft at RC scale. The fuselage I need to have machined from 1 lb. foam is about 6' 2" min length, and very simple in shape. (not looking for a Class A finish here) So, to those of you who can machine such parts, what would you expect the machining cost to be? (I can supply the file in STL or STP format.) Ideally, we'd like to do this work in the next couple of weeks. Let me know... Thanks!
    The plan is to cut two (left and right) fuselage halves. Each fuselage half is 6 ft. long, 14 inches tall, and 7 inches wide.
    Attached Thumbnails Attached Thumbnails Request for foam-cutting bids-foam_cut_size-jpg
    Dec 2004
    Default Re: Request for foam-cutting bids
    Thanks to those who had a look here. This request is now filled, so this thread can be ignored or deleted.
