- H code problem
H code problem
Hello
I am running ECOTURN 100 with Fanuc 0-T controller.
I am tring to write a simple macro code (which is only of A type) but every time p/s alarm 078 is generated.
I have checked different methods to find out where the problem exactly is until I almost came to the concolusion that G65 gives an error every time it reaches “H” number.
To show this by a simple example even if I run this program:
G65 H80 Pn;
Nn;
then p/s 078 appears.
If I remove H, it will easily refer to program O number and works well, but that’s all G65 can do for you because you can’t use any H code!
I would be grateful if you could explain this problem.
- H code problem
- You may not post replies
- You may not edit your posts
Forum Rules
