- Haas Macro automated tool selection?
hi!
new to macros, and i had a question about how I could do an automated tool selection.
I have a bracket that is made about 10 times a day.
simple clearance bore with 4 bolt holes surrounding, made in rec tubing, however all the dimensions are different for each one.
I am trying to write a program that will cut out the programmer and allow the operator to enter in a few important variables so the controller can do the rest
is it possible to have the controller choose which tool to select?
for instance:
#33=1.0 (BORE DIA)
IF[#33 GE 1] ......(IDEALLY I'D LIKE IT TO CHOOSE THE 1" DRILL)
this isnt operation though, currently we drill the bore and G12 to size with an EM
is there any way to automate this?
I'd like to just have the operator enter in a few important sizes of the bracket and the rest do on its own if at all possible.
Thanks!
Re: Haas Macro automated tool selection?
if this is a straight drill size to tool #
IF[#33 EQ 1 ]THEN #100=1(TOOL#1)
GOTO100
IF[#33 EQ 1.5]THEN#100=2(TOOL 2)
GOTO100
GOTO9999 (IF THERE IS NO EQUIVALENT ALARM OUT )
N100
M6T#100
G43H#100Z1.000
(T,H AND D WOULD ALL BE #100 )
N9999(ALARM CODE)
M30
If you are trying to create 10 different parts you can create a list of variables for each part
#500=1(which dash number is it )
IF[#500 EQ 1]GOTO 8000
IF[#500 EQ 2]GOTO 8001
ECT.
N100
M6T#501
G43H#501
PROGRAM BLA BLA BLA
G12D#502I#503K#504 ECT.
M30
N8000 (DASH #1)
#501=1(T10)
#502=.375(D -TOOL RADIUS)
#503=.425(I- RADIUS OF FIRST CIRCLE)
#504=..500 (K -RADIUS OF FINISHED CIRCLE)
#505=ECT.
GOTO100
* D - Tool radius or diameter selection**
F - Feedrate
I - Radius of first circle (or finish if no K). I value must be greater than Tool Radius, but less than K value.
* K - Radius of finished circle (if specified)
* L - Loop count for repeating deeper cuts
* Q - Radius increment, or stepover (must be used with K)
Z - Depth of cut or increment
Thank you so much!
I suspected I could use the variables with the T address like that.
I dont have any way of testing my codes so I'm pretty limited on what I can learn.
- You may not post replies
- You may not edit your posts
Forum Rules
