I think that it is not too easy as you write. Which Biesse machine you have ?
I want to convert some programs from my Biesse to Masterwood.
The G code seems easy to convert but have no documentation with the Masterwoods machine on variables, variable looping and operators/ functions(i.e.. rounding numbers to a whole, square root, sine, cosine etc)
looking on the web for help I believe variables on the Masterwood look something like this:-
#1=10
#2=200/#1
therefore:-
#2=20
Any help would be appreciated.
Postprocessors, VBA macros, .NET programming.
www.ccsoftcz.com
What masterwood machine are you running?
I am running a Project 350. I have got a handle on the parametrics see below(this is a simple verticle grooved door):-
:1
G120 K1
M61 K1 D1
M116 K1
#3=110 ( Stile
(DO NOT ALTER VAIABLES BELOW
#500=INT((DY-(#3*2))/100+1) (Number of spaces
#501=(DY-(#3*2))/#500 (Groove distance
#502=0 ( Counter of grooves
#600=-7
#604=-#600--DX (X Movement Direction
#WHILE #502<=#500
#502=#502+1
#605=#501*#502+(#3-#501) (Y Movement Direction
G172 X=#604 Y=#605 Z5 S18 E2 T91/9
#604=-#604--DX
G101 X=#604 Y=#605 Z5 F13
M116 K0
#WEND
Where I am now struggling is have a method of turning a door over midway through a program(we groove doors both sides but also line up cut outs(for glass) with the grooves after the second side is grooved). I also want to configure the machine to lift pins once panel is complete. Attached is my Gcode for lifting pins/vac off/panel lifter up. Pause just tells me it has run the code. I get the pause working but nothing else works:-
:1
(Lift x and y stops
M202 K1 10 100;2 01 100
(Vacumm off
M209 K1 00 0;2 00 0
(Panel lifter on
M207 K1 1;2 1;3 1;4 1
(Pause to show machine has run code
M00
I suspect either I have the syntax incorrect or data corruption on the PC. We had a similar problem with the guard not moving when asked by M61 but all the other code worked due to corrupt files. The machine was sold as working but had a lot of corrupt files which the supplier fixed(I suspect it still has more left)
