Newbie Not able to write macro on Fanuc OT Series
Results 1 to 9 of 9
Thread: Not able to write macro on Fanuc OT Series
    Registered Ashish B's Avatar
    May 2009
    India
    Default Not able to write macro on Fanuc OT Series
    I just wrote a macro Program on Fanuc Oi mate - TD control. The program works fine on Fanuc Oi Mate control.
    I also want to implement the same on my older machines which have Fanuc O T control.
    I am not able to type the following things on old control -
    1. #3000 = 1 (To generate alarm)
    2. #501 = #2801 (To copy geometry offset in common variable)
    3. If [#510 GT #509] GOTO 999 (This is the tool offset check condition)
    Please require assistance on how to write these codes on older machine or can it be accomplished by some other codes?
    Ashish
    Attached Thumbnails Attached Thumbnails Not able to write macro on Fanuc OT Series-images-1-jpg
    May 2015
    Default Re: Not able to write macro on Fanuc OT Series
    Is this because the controls don't have a full keyboard? If so, you can write the macros on your PC then transfer the program via RS-232 or Ethernet.
    Feb 2009
    You sure you have macro on the old control? Was an option back then.
    Sent from my A3-A20FHD using Tapatalk
    May 2009
    India
    Hey it that really possible? If I transfer that codes via RS232C port then can I really run the program on older machine.
    May 2015
    Quote Originally Posted by Ashish B View Post
    If the control has the Macro A or Macro B option, yes.
    May 2009
    India
    How to check whether the machine supports Macro A or Macro B on my old machine?
  7. #7
    Jan 2016
    In MDI type #100= 1
    If your machine alarms it can't read macros. I'm not sure about the difference between A & B. I work with YASNAC machines.
  8. #8
    Jul 2010
    South Africa
    one of these examples will create a alarm
    Macro A format
    b)Addition #i = #j + #k
    G65 H02 P#i Q#j R#k;
    [Example] G65 H02 P#101 Q#102 R15 ; (#101=#102+15)
    Macro B format
    #100=#101+15
  9. #9
    May 2009
    India
    But how to type # or = character on the control
    As all can see in the attachment, I type the buttons below DELETE button, then is it not getting typed.
    That # character is only typed when I type certain alphabetical character such as A, B
    Attached Thumbnails Attached Thumbnails Not able to write macro on Fanuc OT Series-images-1-_1-jpg
