OLD BLUEPRINT DIMENSION QUESTION.
Results 1 to 11 of 11
Thread: OLD BLUEPRINT DIMENSION QUESTION.
    Member CEMENTHE4D's Avatar
    Nov 2019
    Question OLD BLUEPRINT DIMENSION QUESTION.
    We have a job that details a square taper as...
    ______________________
    .50 PF LARGE END
    OF SQUARE .75
    PER FOOT TAPER
    (TOTAL)
    The "PF" is throwing me off. I'm assuming Press Fit?
    Never seen it detailed like that before.
    TIA ~CH
    Member mactec54's Avatar
    Jan 2005
    Default Re: OLD BLUEPRINT DIMENSION QUESTION.
    Quote Originally Posted by CEMENTHE4D View Post
    .50 PF LARGE END
    OF SQUARE .75
    PER FOOT TAPER
    (TOTAL)
    TIA ~CH
    The PF is per foot taper without seeing the drawing it does not make much sense the way that this is written
    Mactec54
    Nov 2019
    It's written exactly the way I typed it out. only thing missing is the Arrow pointing to the square on the end of a shaft.
    Jan 2005
    Is there a thread involved
    Mactec54
    Nov 2019
    .375-16 UNC 2A on Square end and a 1.5-4 acme on the shaft.
    Jan 2005
    It makes a little more sense the PF is not per foot it is a reference to a Thread JIS PF series thread so it is basally saying a Parallel Pipe thread, but your threads don't match up to that so still unknown as to what they mean, unless the thread was changed at some time, what is this drawings origin
    Mactec54
  7. #7
    Nov 2019
    snippet
    Attached Thumbnails Attached Thumbnails OLD BLUEPRINT DIMENSION QUESTION.-untitled-jpg
  8. #8
    Mar 2009
    us
    I could be wrong but in my mind I'm thinking the .50 PF designates Press Fit. There is already a taper per foot callout (.75), hence the reason for such a tight tolerance at the small end of the square and finish callout as well. If I had to guess I would say that square gets press fit into a mating part and yet another part screws on the end to hold it in place.
  9. #9
    Jan 2005
    Quote Originally Posted by z369 View Post
    It's a Taper so would not be a press fit designed like it is, that also has a large tolerance +/- .010" .50= 2 decimal places=+/- .010"
    Looking at the drawing snip I would say the drawing was changed at some time and this is a mistake as it does not reference anything
    PF designates a JIS parallel pipe thread
    Mactec54
  10. #10
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi - This wiki says PF is press fit. Peter
    https://en.wikipedia.org/wiki/Engine...ns_and_symbols
  11. #11
    Jan 2005
    Quote Originally Posted by peteeng View Post
    It is not going to be a Press Fit with a +/- .010" tolerance
    Note how it is used P.S. = Press Fit not just straight PS = Parallel thread for Jis standard, so it has more than one meaning depending on how it is written and what it is referring too
    I wonder if the Machinery Hand Book has how it should be used
    Mactec54
