Precision Acme thread movement with help of encoder.
Results 1 to 4 of 4
Thread: Precision Acme thread movement with help of encoder.
    Activation process cncstudies's Avatar
    Dec 2018
    Default Precision Acme thread movement with help of encoder.
    Hello All
    I have built a large Z axis with using 40mm x 5mm pitch precision Acme thread rod (0.01mm tolerance). The rod is turned via a planetary 100:1 gearbox fixed to a 1.5kw Servo motor. The idea is that the Acme nut(which is fixed to a plate )must allow this plate to move move in 50 micron step. The problem I face is that being a large Z Axis, the gearbox movement may not respond to such a minute movement of 50 microns, despite the servo "reaching its 50micron" motion through its built in encoder. I would like to put an encoder on the acme nut but how do i control the servo with this encoder? All help will be appreciated
    Member awerby's Avatar
    Apr 2004
    Default Re: Precision Acme thread movement with help of encoder.
    I don't think the controller cares where the encoder is mounted. It's usually on the back of the motor for convenience, but with all the backlash from the gear train, I can see why you'd want to monitor the screw instead. You should be able to remove and re-mount it, but if that doesn't work, use a different but similar one on the screw. Just realize that the encoder won't be able to tell if the spindle moves 50 microns; it will only tell you what the screw does, but its backlash will likely take up most or all of that on a change of direction.
    Nov 2013
    what is your Z axis servo?.
    An AC servo using FOC (Field Oriented Control) requires an encoder which is intimately linked to the servo. Any lash or other non-linearity will almost certainly screw the servo operation ie
    the encoder has to be mounted on the servo shaft.
    There are other servos, somewhat specialist, that can have two encoders. The first encoder and the main one is the servo mounted rotary encoder, and that has to be there in order for FOC to work,
    but has an auxiliary encoder that can close the position loop. The auxiliary encoder could be a linear scale, another rotary encoder linked direct to the ACME or a LDVT or even an interferometer
    as might be use in ultra precision semiconductor machines. This is called 'load sensing'. The load is the actual position of the Z axis.
    As an example the Delta A2 series of servos have this auxiliary encoder or load sensing input. The normal B2 series servos (that don't have this load sensing feature) are $438USD (750W kit) while
    the A2 series is $634USD (750W kit)....so you pay for the feature. I mention Delta because I use Delta B2's in my machine and am familiar with them, but most of the top tier servo manufacturers
    have models that have this load sensing feature. Somewhat specialised and more expensive.
    Craig
    Jan 2008
    What CNC controller?
