Build of ORD Bot Hadron - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 29 of 29
Thread: Build of ORD Bot Hadron
  1. #25
    Registered cozmicray's Avatar
    Jun 2004
    Default OrdBot hadron build
    Repetier-host allows you to use Slic3r or Skeinforge for slicing
    so you can choose either to do the slicing.
    Make sure you have the steppermotor drivers on the RAMPS
    I scratched for a while when motors wouldn't move then realized
    I got RAMPS board without polulu driver boards
    Check out buildnet Hadron Build (ATI kit) quick heads up
    buildlog.net • View topic - Hadron Build (ATI kit) quick heads up
    for ATI BOM and top level drawings for assembly
    No instructions in ATI box
    and what fasteners to use where is not well documented.
    You should look for some endstop switches to have ready for hook up
    Mechanical switches or optical, hall effect. Need 3 for home position.
    I have built -- rebuilt -- and fixed it a bunch
    and got alot of improvements for the next rebuild
    Just ask if you have questions?
    Ray
  2. #26
    Registered port_huon's Avatar
    Dec 2007
    Hi Mal,
    Sorry for the delay in answering, I don't check cnczone as often as a I used to - got fed up with the constant spam.
    I ordered a complete Hadron kit, mechanical and electronics from ATI on 15/09, I received it about 1 month later. It was shipped in two boxes, shipping for each via USPS was around $69.
    I bought some extra bits and pieces (extra stepper drivers, end stop switches and an LCD display) from eBay seller reprapdiscount.
    I've still to tackle the electronics side of things, other stuff keeps getting in the way.
    Regards
    Geoff
  3. #27
    Jun 2004
    Default Ordbot Hadron alignment Y square to Z
    There is really nothing on the Ordbot Hadron to square (90deg) Y axis to Z axis.
    The connection of Z frame to Y axis is very sloppy and can be well off square
    and move in the life of the printer, after moving printer.
    Anybody got any suggestions on how to square the Hadron and keep it that way?
    Tnx
    Ray
  4. #28
    Oct 2005
    Just finished the mechanical build of a Ord Bot Hadron. I ordered it from ATI. Received it in two days. The kit was complete without any missing parts or shipping damage. I had one question during the build that I emailed at 7 or 8 o'clock at night, an answer came a few minutes later. Before I ordered the kit I looked around a lot. The kit had all the upgrades included, for the price and delivery time I found this to be a very good value.
    I also ordered Ramps 1.4 Ultimate kit from RepRapDiscount. Again delivered from China in two days. I have not received the extruder or hot end yet.
    I have tested the steppers and loaded new firmware to the ramps board.
    So far I have been impressed with the quality and value for the items I have received to date.Build of ORD Bot Hadron-my_ord_bot-jpg
  5. #29
    May 2010
    Default Re: Build of ORD Bot Hadron
    ORD Bot Hadron 3D printer mechanical platform Kit is only $299 now
    http://www.automationtechnologiesinc...l-platform-kit
    KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
