windows 10 issues
Results 1 to 5 of 5
Thread: windows 10 issues
    Unhappy windows 10 issues
    Hi, had to replace old computer (windows xp and nc studio via pci card) new one is windows 10, 64 bit, wont run nc studio, need pci card or some other way to run chinese router Dw1325 3 axis, What do others do re windows 10? any suggestions welcome as sanity hanging by a thread
    Doug,
    Aug 2017
    Default Re: windows 10 issues
    Would installing windows 10 , 32bit help.
    Hi Liefer, I’ve been told that it wont work at all on win10, am go back to win7 32 bit. this will have to do until nc studio catches up with win10
    thanks for the reply, will post how it went, Cheers, Doug
    got new computer, loaded win7, works but my original issue( unpredictable x movement ) is still happening. replaced stepper motor and driver, had other components checked and repaired, spent a thousand dollars and still same issue, how do i find where the failure is?.i
    Aug 2017
    I'm still working on my cnc conversion but so far I have been able to jog all axis with Mach3 without any problems.
    I started out with a windows7 64bit PC but found out the 64bit doesn't have a P-port driver so I reinstalled windows7 32bit
    and like I said jogging works on all axis.
    Some versions of mach3 are buggy but I don't know which ones. Also some windows updates cause problems with Mach3 and4.
windows 10 issues
windows 10 issues
