G-Code to DXF - Page 2
Page 2 of 12 FirstFirst 12345 ... LastLast
Results 21 to 40 of 229
Thread: G-Code to DXF
  1. #21
    Registered MetLHead's Avatar
    Mar 2003
    Quote Originally Posted by WayneHill View Post
    Scott,
    Email me a copy of the G-code that you are trying to convert and will look for the problem.
    wayne_j_hill at yahoo dot com
    Wayne
    Wayne,
    Sorry, I was responding to edavidtucker.
    Scott
  2. #22
    Member WayneHill's Avatar
    Mar 2004
    Michigan
    edavidtucker,
    Scott - What type of software do you mangle?
    Wayne Hill
  3. #23
    Mar 2003
    Wayne,
    I work on a lot of CNC related stuff, NCPlot is my baby.
    Scott
  4. #24
    Oct 2006
    Default A sample of our g-code
    O0009
    (1681-31C-55996-9-O0009)
    G92X72.000Y50.000
    G72X11.883Y13.964
    G66I10.802J180.00P-1.984Q-0.200T228 (.200 X 1.984 RT #0)
    G72X3.482Y12.232
    G66I6.500J360.00P-1.984Q-0.200
    X3.582Y10.232T201 (.200 X 4.000 RT #90)
    X0.650Y11.732
    X4.857Y12.523T219 (CRITICAL ENVIRONMENT LOGO #0)
    X4.857Y12.958T255 (TERRA UNIVERSAL LOGO #0)
    X2.618Y8.732T107 (.107 RD)
    X1.618
    Y7.732
    X2.618
    X11.170Y4.111T208 (.156 RD)
    Y5.061
    Y11.282
    Y12.232
    X12.059Y13.888T313 (.312 SQ #0)
    X0.905
    Y2.576
    X12.059
    G72X12.214Y13.782
    G66I11.100J-90.00P4.000Q0.200T201 (.200 X 4.000 RT #0)
    G72X9.982Y4.232
    G66I8.000J90.00P4.000Q0.200
    X3.582Y6.232
    X0.650Y7.732
    Y4.682
    G72X3.712Y4.232
    G66I6.040J-0.00P1.984Q0.200T228 (.200 X 1.984 RT #0)
    G72X11.883Y2.500
    G66I10.802J180.00P1.984Q0.200
    G50
    SET-UP SHEET
    CUSTOMER NAME : TERRA UNIVERSAL
    NC FILE NAME : C:\FabriWIN\NCFiles\1681-31C-55996\1681-31C-55996-09-O0009.gcd
    SHEET FILE NAME : 1681-31C-55996-09
    PART FILE NAME : 1681-31C-55996-09
    PART SIZE : 11.464 X 11.464
    OFFSET : 0.750 X 2.500
    SPACE BETWEEN : 0 X 0
    YIELD PER BLANK : 1 PART
    MATERIAL : 18GA 304 SS 2PVC
    THICKNESS : 0.048
    BLANK SIZE : 13.000 X 15.000
    SHEET USAGE : 0.61%
    TOOL LIST
    STATION TYPE ANGLE SIZE HITS
    T107 ROUND 0.125 4
    T208 ROUND 0.156 4
    T313 SQUARE 0.00 0.312 4
    T219 RECTANGLE 0.00 0.125 X 2.750 1
    T228 RECTANGLE 0.00 0.200 X 1.984 20
    T201 RECTANGLE 90.00 0.200 X 4.000 11
    T255 RECTANGLE 0.00 0.625 X 2.750 1
    CLAMPS : 3.50 9.13
    ESTIMATED TIME : 0 MIN. 27 SEC.
    PROGRAMMED BY : ERIC R
    DATE : 10-13-2006
    TIME : 13:04
    COMMENTS
    GRAIN IN X DIRECTION
  5. #25
    Mar 2004
    Michigan
    David - G-Code to DXF program was made to convert simple CNC mill code profiles to DXF. There are many G-code applications this program will not handle. Unfortunately a turret press code is one of them. Lathe G-Code is another. You never know until you try. Sorry.
    Scott - Your are perty good at that code mangling. I visited your web site. Lots of good things going on there.
    Wayne Hill
    Wayne Hill
  6. #26
    Aug 2006
    Can anyone port this to a mac program or at least a perl script? (if it's possible...)
  7. #27
    Mar 2004
    Michigan
    Quote Originally Posted by Exprice View Post
    Exprice.
    I know nothing about Mac or Perl , but I am willing to guide you on the logic on how it is comverted.
    Wayne
    Wayne Hill
  8. #28
    Mar 2006
    edavidtucker,
    Wayne your program is what i have been trying to find for a long time, but when i run it and bring the dxf file into autocad it just consist of some circles, and extreme amount of line usually converging into one point, i will email you a sample of the work ok. glenn
  9. #29
    Mar 2004
    Michigan
    bumper (Glenn)
    I will take a look at it. My email address:
    Wayne
    Wayne Hill
  10. #30
    Mar 2004
    Michigan
    Glenn,
    The program you sent has I and J values the program was having trouble converting. My program works with I and J values that are the incremental distance from the start point of the circle to the center of the circle. It will also convert G02 and G03 with R values.
    Attached are two G02/G03 G-Code programs that work fine with the Gcode2DXF program.
    Code:
    N0010 G40 G17 G90 G20
    N0020 G43 T02 H02 M06
    N0030 G01 X.0037 Y.1633 Z.1 F20. S0 M03
    N0040 G01 X0.0 Y.1696 Z.0981 F10.
    N0050 G01 X-.0241 Y.128 Z.0852 F10.
    N0060 G01 X-.0888 Y.0366 Z.0552 F10.
    N0070 G01 X-.12 Y0.0 Z.0423 F10.
    N0080 G01 X-.0888 Y-.0366 Z.0294 F10.
    N0090 G01 X-.0241 Y-.128 Z-.0006 F10.
    N0100 G01 X0.0 Y-.1696 Z-.0135 F10.
    N0110 G01 X.0241 Y-.128 Z-.0264 F10.
    N0120 G01 X.0888 Y-.0366 Z-.0563 F10.
    N0130 G01 X.12 Y0.0 Z-.0692 F10.
    N0140 G01 X.0888 Y.0366 Z-.0821 F10.
    N0150 G01 X.0241 Y.128 Z-.1121 F10.
    N0160 G01 X0.0 Y.1696 Z-.125 F10.
    N0170 G17 G02 X-.12 Y0.0 Z-.125 I-1. J.5804 K0.0 F10.
    N0180 G17 G02 X0.0 Y-.1696 Z-.125 I-.88 J-.75 K0.0 F10.
    N0190 G17 G02 X.12 Y0.0 Z-.125 I1. J-.5804 K0.0 F10.
    N0200 G17 G02 X0.0 Y.1696 Z-.125 I.88 J.75 K0.0 F10.
    N0210 G01 X.0811 Y.2166 Z-.125 F10.
    N0220 G17 G02 X0.0 Y.391 Z-.125 I.9189 J.5334 K0.0 F10.
    N0230 G17 G02 X-.2474 Y0.0 Z-.125 I-1. J.359 K0.0 F10.
    N0240 G17 G02 X0.0 Y-.391 Z-.125 I-.7526 J-.75 K0.0 F10.
    N0250 G17 G02 X.2474 Y0.0 Z-.125 I1. J-.359 K0.0 F10.
    N0260 G17 G02 X.0811 Y.2166 Z-.125 I.7526 J.75 K0.0 F10.
    N0270 G01 X.1622 Y.2637 Z-.125 F10.
    N0280 G17 G02 X.0563 Y.5312 Z-.125 I.8378 J.4863 K0.0 F10.
    N0290 G01 X-.0563 Y.5312 Z-.125 F10.
    N0300 G17 G02 X-.3868 Y0.0 Z-.125 I-.9437 J.2188 K0.0 F10.
    N0310 G17 G02 X-.0882 Y-.4226 Z-.125 I-.6132 J-.75 K0.0 F10.
    N0320 G17 G02 X-.0563 Y-.5312 Z-.125 I-.9118 J-.3274 K0.0 F10.
    N0330 G01 X.0563 Y-.5312 Z-.125 F10.
    N0340 G17 G02 X.0882 Y-.4226 Z-.125 I.9437 J-.2188 K0.0 F10.
    N0350 G17 G02 X.3868 Y0.0 Z-.125 I.9118 J-.3274 K0.0 F10.
    N0360 G17 G02 X.1622 Y.2637 Z-.125 I.6132 J.75 K0.0 F10.
    N0370 G01 X.2432 Y.3107 Z-.125 F10.
    N0380 G17 G02 X.134 Y.625 Z-.125 I.7568 J.4393 K0.0 F10.
    N0390 G01 X-.134 Y.625 Z-.125 F10.
    N0400 G17 G02 X-.5493 Y0.0 Z-.125 I-.866 J.125 K0.0 F10.
    N0410 G17 G02 X-.134 Y-.625 Z-.125 I-.4507 J-.75 K0.0 F10.
    N0420 G01 X.134 Y-.625 Z-.125 F10.
    N0430 G17 G02 X.5493 Y0.0 Z-.125 I.866 J-.125 K0.0 F10.
    N0440 G17 G02 X.2432 Y.3107 Z-.125 I.4507 J.75 K0.0 F10.
    N0450 G01 X.3243 Y.3578 Z-.125 F10.
    N0460 G17 G02 X.2194 Y.7187 Z-.125 I.6757 J.3922 K0.0 F10.
    N0470 G01 X-.2194 Y.7187 Z-.125 F10.
    N0480 G17 G02 X-.7187 Y.0211 Z-.125 I-.7806 J.0313 K0.0 F10.
    N0490 G01 X-.7187 Y-.0211 Z-.125 F10.
    N0500 G17 G02 X-.2194 Y-.7187 Z-.125 I-.2813 J-.7289 K0.0 F10.
    N0510 G01 X.2194 Y-.7187 Z-.125 F10.
    N0520 G17 G02 X.7187 Y-.0211 Z-.125 I.7806 J-.0313 K0.0 F10.
    N0530 G01 X.7187 Y.0211 Z-.125 F10.
    N0540 G17 G02 X.3243 Y.3578 Z-.125 I.2813 J.7289 K0.0 F10.
    N0550 G01 X.4054 Y.4049 Z-.125 F10.
    N0560 G17 G02 X.3125 Y.75 Z-.125 I.5946 J.3451 K0.0 F10.
    N0570 G01 X.3125 Y.8125 Z-.125 F10.
    N0580 G01 X-.3125 Y.8125 Z-.125 F10.
    N0590 G01 X-.3125 Y.75 Z-.125 F10.
    N0600 G17 G02 X-.8125 Y.0886 Z-.125 I-.6875 J0.0 K0.0 F10.
    N0610 G01 X-.8125 Y-.0886 Z-.125 F10.
    N0620 G17 G02 X-.3125 Y-.75 Z-.125 I-.1875 J-.6614 K0.0 F10.
    N0630 G01 X-.3125 Y-.8125 Z-.125 F10.
    N0640 G01 X.3125 Y-.8125 Z-.125 F10.
    N0650 G01 X.3125 Y-.75 Z-.125 F10.
    N0660 G17 G02 X.8125 Y-.0886 Z-.125 I.6875 J0.0 K0.0 F10.
    N0670 G01 X.8125 Y.0886 Z-.125 F10.
    N0680 G17 G02 X.4054 Y.4049 Z-.125 I.1875 J.6614 K0.0 F10.
    N0690 G01 X.4865 Y.4519 Z-.125 F10.
    N0700 G17 G02 X.4062 Y.75 Z-.125 I.5135 J.2981 K0.0 F10.
    N0710 G01 X.4062 Y.9062 Z-.125 F10.
    N0720 G01 X-.4062 Y.9062 Z-.125 F10.
    N0730 G01 X-.4062 Y.75 Z-.125 F10.
    N0740 G17 G02 X-.9062 Y.1637 Z-.125 I-.5938 J0.0 K0.0 F10.
    N0750 G01 X-.9062 Y-.1637 Z-.125 F10.
    N0760 G17 G02 X-.4062 Y-.75 Z-.125 I-.0938 J-.5863 K0.0 F10.
    N0770 G01 X-.4062 Y-.9062 Z-.125 F10.
    N0780 G01 X.4062 Y-.9062 Z-.125 F10.
    N0790 G01 X.4062 Y-.75 Z-.125 F10.
    N0800 G17 G02 X.9062 Y-.1637 Z-.125 I.5938 J0.0 K0.0 F10.
    N0810 G01 X.9062 Y.1637 Z-.125 F10.
    N0820 G17 G02 X.4865 Y.4519 Z-.125 I.0938 J.5863 K0.0 F10.
    N0830 G01 X.5676 Y.499 Z-.125 F10.
    N0840 G17 G02 X.5 Y.75 Z-.125 I.4324 J.251 K0.0 F10.
    N0850 G01 X.5 Y1. Z-.125 F10.
    N0860 G01 X-.5 Y1. Z-.125 F10.
    N0870 G01 X-.5 Y.75 Z-.125 F10.
    N0880 G17 G02 X-1. Y.25 Z-.125 I-.5 J0.0 K0.0 F10.
    N0890 G01 X-1. Y-.25 Z-.125 F10.
    N0900 G17 G02 X-.5 Y-.75 Z-.125 I0.0 J-.5 K0.0 F10.
    N0910 G01 X-.5 Y-1. Z-.125 F10.
    N0920 G01 X.5 Y-1. Z-.125 F10.
    N0930 G01 X.5 Y-.75 Z-.125 F10.
    N0940 G17 G02 X1. Y-.25 Z-.125 I.5 J0.0 K0.0 F10.
    N0950 G01 X1. Y.25 Z-.125 F10.
    N0960 G17 G02 X.5676 Y.499 Z-.125 I0.0 J.5 K0.0 F10.
    N0970 G01 X.6486 Y.5461 Z-.125 F10.
    N0980 G17 G02 X.5937 Y.75 Z-.125 I.3514 J.2039 K0.0 F10.
    N0990 G01 X.5937 Y1.0937 Z-.125 F10.
    N1000 G01 X-.5937 Y1.0937 Z-.125 F10.
    N1010 G01 X-.5937 Y.75 Z-.125 F10.
    N1020 G17 G02 X-1. Y.3437 Z-.125 I-.4063 J0.0 K0.0 F10.
    N1030 G01 X-1.0937 Y.3437 Z-.125 F10.
    N1040 G01 X-1.0937 Y-.3437 Z-.125 F10.
    N1050 G01 X-1. Y-.3437 Z-.125 F10.
    N1060 G17 G02 X-.5937 Y-.75 Z-.125 I0.0 J-.4063 K0.0 F10.
    N1070 G01 X-.5937 Y-1.0937 Z-.125 F10.
    N1080 G01 X.5937 Y-1.0937 Z-.125 F10.
    N1090 G01 X.5937 Y-.75 Z-.125 F10.
    N1100 G17 G02 X1. Y-.3437 Z-.125 I.4063 J0.0 K0.0 F10.
    N1110 G01 X1.0937 Y-.3437 Z-.125 F10.
    N1120 G01 X1.0937 Y.3437 Z-.125 F10.
    N1130 G01 X1. Y.3437 Z-.125 F10.
    N1140 G17 G02 X.6486 Y.5461 Z-.125 I0.0 J.4063 K0.0 F10.
    N1150 G01 X.7297 Y.5931 Z-.125 F10.
    N1160 G17 G02 X.6875 Y.75 Z-.125 I.2703 J.1569 K0.0 F10.
    N1170 G01 X.6875 Y1.1875 Z-.125 F10.
    N1180 G01 X-.6875 Y1.1875 Z-.125 F10.
    N1190 G01 X-.6875 Y.75 Z-.125 F10.
    N1200 G17 G02 X-1. Y.4375 Z-.125 I-.3125 J0.0 K0.0 F10.
    N1210 G01 X-1.1875 Y.4375 Z-.125 F10.
    N1220 G01 X-1.1875 Y-.4375 Z-.125 F10.
    N1230 G01 X-1. Y-.4375 Z-.125 F10.
    N1240 G17 G02 X-.6875 Y-.75 Z-.125 I0.0 J-.3125 K0.0 F10.
    N1250 G01 X-.6875 Y-1.1875 Z-.125 F10.
    N1260 G01 X.6875 Y-1.1875 Z-.125 F10.
    N1270 G01 X.6875 Y-.75 Z-.125 F10.
    N1280 G17 G02 X1. Y-.4375 Z-.125 I.3125 J0.0 K0.0 F10.
    N1290 G01 X1.1875 Y-.4375 Z-.125 F10.
    N1300 G01 X1.1875 Y.4375 Z-.125 F10.
    N1310 G01 X1. Y.4375 Z-.125 F10.
    N1320 G17 G02 X.7297 Y.5931 Z-.125 I0.0 J.3125 K0.0 F10.
    N1330 G01 X.9196 Y.2777 Z-.125 F10.
    N1340 G17 G03 X.8587 Y.583 Z-.125 I-.2223 J.1144 K0.0 F10.
    N1350 G17 G02 X.8108 Y.6402 Z-.125 I.1413 J.167 K0.0 F10.
    N1360 G17 G02 X.7812 Y.75 Z-.125 I.1892 J.1098 K0.0 F10.
    N1370 G01 X.7812 Y1.2812 Z-.125 F10.
    N1380 G01 X-.7812 Y1.2812 Z-.125 F10.
    N1390 G01 X-.7812 Y.75 Z-.125 F10.
    N1400 G17 G02 X-1. Y.5312 Z-.125 I-.2188 J0.0 K0.0 F10.
    N1410 G01 X-1.2812 Y.5312 Z-.125 F10.
    N1420 G01 X-1.2812 Y-.5312 Z-.125 F10.
    N1430 G01 X-1. Y-.5312 Z-.125 F10.
    N1440 G17 G02 X-.7812 Y-.75 Z-.125 I0.0 J-.2188 K0.0 F10.
    N1450 G01 X-.7812 Y-1.2812 Z-.125 F10.
    N1460 G01 X.7812 Y-1.2812 Z-.125 F10.
    N1470 G01 X.7812 Y-.75 Z-.125 F10.
    N1480 G17 G02 X1. Y-.5312 Z-.125 I.2188 J0.0 K0.0 F10.
    N1490 G01 X1.2812 Y-.5312 Z-.125 F10.
    N1500 G01 X1.2812 Y.5312 Z-.125 F10.
    N1510 G01 X1. Y.5312 Z-.125 F10.
    N1520 G17 G02 X.7849 Y.7102 Z-.125 I0.0 J.2188 K0.0 F10.
    N1530 G17 G03 X.6502 Y.8886 Z-.125 I-.2458 J-.0455 K0.0 F10.
    N1540 G01 X1.0827 Y.3574 Z-.125 F10.
    N1550 G17 G03 X.9462 Y.6372 Z-.125 I-.2441 J.0541 K0.0 F10.
    N1560 G17 G02 X.8919 Y.6872 Z-.125 I.0538 J.1128 K0.0 F10.
    N1570 G17 G02 X.875 Y.75 Z-.125 I.1081 J.0628 K0.0 F10.
    N1580 G01 X.875 Y1.375 Z-.125 F10.
    N1590 G01 X-.875 Y1.375 Z-.125 F10.
    N1600 G01 X-.875 Y.75 Z-.125 F10.
    N1610 G17 G02 X-1. Y.625 Z-.125 I-.125 J0.0 K0.0 F10.
    N1620 G01 X-1.375 Y.625 Z-.125 F10.
    N1630 G01 X-1.375 Y-.625 Z-.125 F10.
    N1640 G01 X-1. Y-.625 Z-.125 F10.
    N1650 G17 G02 X-.875 Y-.75 Z-.125 I0.0 J-.125 K0.0 F10.
    N1660 G01 X-.875 Y-1.375 Z-.125 F10.
    N1670 G01 X.875 Y-1.375 Z-.125 F10.
    N1680 G01 X.875 Y-.75 Z-.125 F10.
    N1690 G17 G02 X1. Y-.625 Z-.125 I.125 J0.0 K0.0 F10.
    N1700 G01 X1.375 Y-.625 Z-.125 F10.
    N1710 G01 X1.375 Y.625 Z-.125 F10.
    N1720 G01 X1. Y.625 Z-.125 F10.
    N1730 G17 G02 X.875 Y.75 Z-.125 I0.0 J.125 K0.0 F10.
    N1740 G01 X.875 Y.7593 Z-.125 F10.
    N1750 G17 G03 X.775 Y.9593 Z-.125 I-.25 J0.0 K0.0 F10.
    N1760 G01 X.775 Y.9593 Z-.025 F20.
    N1770 G01 X.775 Y.9593 Z.2 F20.
    N1780 G01 X.0037 Y.1633 Z.2 F20.
    N1790 G01 X.0037 Y.1633 Z-.025 F20.
    N1800 G01 X0.0 Y.1696 Z-.0269 F10.
    N1810 G01 X-.0241 Y.128 Z-.0398 F10.
    N1820 G01 X-.0888 Y.0366 Z-.0698 F10.
    N1830 G01 X-.12 Y0.0 Z-.0827 F10.
    N1840 G01 X-.0888 Y-.0366 Z-.0956 F10.
    N1850 G01 X-.0241 Y-.128 Z-.1256 F10.
    N1860 G01 X0.0 Y-.1696 Z-.1385 F10.
    N1870 G01 X.0241 Y-.128 Z-.1514 F10.
    N1880 G01 X.0888 Y-.0366 Z-.1813 F10.
    N1890 G01 X.12 Y0.0 Z-.1942 F10.
    N1900 G01 X.0888 Y.0366 Z-.2071 F10.
    N1910 G01 X.0241 Y.128 Z-.2371 F10.
    N1920 G01 X0.0 Y.1696 Z-.25 F10.
    N1930 G17 G02 X-.12 Y0.0 Z-.25 I-1. J.5804 K0.0 F10.
    N1940 G17 G02 X0.0 Y-.1696 Z-.25 I-.88 J-.75 K0.0 F10.
    N1950 G17 G02 X.12 Y0.0 Z-.25 I1. J-.5804 K0.0 F10.
    N1960 G17 G02 X0.0 Y.1696 Z-.25 I.88 J.75 K0.0 F10.
    N1970 G01 X.0811 Y.2166 Z-.25 F10.
    N1980 G17 G02 X0.0 Y.391 Z-.25 I.9189 J.5334 K0.0 F10.
    N1990 G17 G02 X-.2474 Y0.0 Z-.25 I-1. J.359 K0.0 F10.
    N2000 G17 G02 X0.0 Y-.391 Z-.25 I-.7526 J-.75 K0.0 F10.
    N2010 G17 G02 X.2474 Y0.0 Z-.25 I1. J-.359 K0.0 F10.
    N2020 G17 G02 X.0811 Y.2166 Z-.25 I.7526 J.75 K0.0 F10.
    N2030 G01 X.1622 Y.2637 Z-.25 F10.
    N2040 G17 G02 X.0563 Y.5312 Z-.25 I.8378 J.4863 K0.0 F10.
    N2050 G01 X-.0563 Y.5312 Z-.25 F10.
    N2060 G17 G02 X-.3868 Y0.0 Z-.25 I-.9437 J.2188 K0.0 F10.
    N2070 G17 G02 X-.0882 Y-.4226 Z-.25 I-.6132 J-.75 K0.0 F10.
    N2080 G17 G02 X-.0563 Y-.5312 Z-.25 I-.9118 J-.3274 K0.0 F10.
    N2090 G01 X.0563 Y-.5312 Z-.25 F10.
    N2100 G17 G02 X.0882 Y-.4226 Z-.25 I.9437 J-.2188 K0.0 F10.
    N2110 G17 G02 X.3868 Y0.0 Z-.25 I.9118 J-.3274 K0.0 F10.
    N2120 G17 G02 X.1622 Y.2637 Z-.25 I.6132 J.75 K0.0 F10.
    N2130 G01 X.2432 Y.3107 Z-.25 F10.
    N2140 G17 G02 X.134 Y.625 Z-.25 I.7568 J.4393 K0.0 F10.
    N2150 G01 X-.134 Y.625 Z-.25 F10.
    N2160 G17 G02 X-.5493 Y0.0 Z-.25 I-.866 J.125 K0.0 F10.
    N2170 G17 G02 X-.134 Y-.625 Z-.25 I-.4507 J-.75 K0.0 F10.
    N2180 G01 X.134 Y-.625 Z-.25 F10.
    N2190 G17 G02 X.5493 Y0.0 Z-.25 I.866 J-.125 K0.0 F10.
    N2200 G17 G02 X.2432 Y.3107 Z-.25 I.4507 J.75 K0.0 F10.
    N2210 G01 X.3243 Y.3578 Z-.25 F10.
    N2220 G17 G02 X.2194 Y.7187 Z-.25 I.6757 J.3922 K0.0 F10.
    N2230 G01 X-.2194 Y.7187 Z-.25 F10.
    N2240 G17 G02 X-.7187 Y.0211 Z-.25 I-.7806 J.0313 K0.0 F10.
    N2250 G01 X-.7187 Y-.0211 Z-.25 F10.
    N2260 G17 G02 X-.2194 Y-.7187 Z-.25 I-.2813 J-.7289 K0.0 F10.
    N2270 G01 X.2194 Y-.7187 Z-.25 F10.
    N2280 G17 G02 X.7187 Y-.0211 Z-.25 I.7806 J-.0313 K0.0 F10.
    N2290 G01 X.7187 Y.0211 Z-.25 F10.
    N2300 G17 G02 X.3243 Y.3578 Z-.25 I.2813 J.7289 K0.0 F10.
    N2310 G01 X.4054 Y.4049 Z-.25 F10.
    N2320 G17 G02 X.3125 Y.75 Z-.25 I.5946 J.3451 K0.0 F10.
    N2330 G01 X.3125 Y.8125 Z-.25 F10.
    N2340 G01 X-.3125 Y.8125 Z-.25 F10.
    N2350 G01 X-.3125 Y.75 Z-.25 F10.
    N2360 G17 G02 X-.8125 Y.0886 Z-.25 I-.6875 J0.0 K0.0 F10.
    N2370 G01 X-.8125 Y-.0886 Z-.25 F10.
    N2380 G17 G02 X-.3125 Y-.75 Z-.25 I-.1875 J-.6614 K0.0 F10.
    N2390 G01 X-.3125 Y-.8125 Z-.25 F10.
    N2400 G01 X.3125 Y-.8125 Z-.25 F10.
    N2410 G01 X.3125 Y-.75 Z-.25 F10.
    N2420 G17 G02 X.8125 Y-.0886 Z-.25 I.6875 J0.0 K0.0 F10.
    N2430 G01 X.8125 Y.0886 Z-.25 F10.
    N2440 G17 G02 X.4054 Y.4049 Z-.25 I.1875 J.6614 K0.0 F10.
    N2450 G01 X.4865 Y.4519 Z-.25 F10.
    N2460 G17 G02 X.4062 Y.75 Z-.25 I.5135 J.2981 K0.0 F10.
    N2470 G01 X.4062 Y.9062 Z-.25 F10.
    N2480 G01 X-.4062 Y.9062 Z-.25 F10.
    N2490 G01 X-.4062 Y.75 Z-.25 F10.
    N2500 G17 G02 X-.9062 Y.1637 Z-.25 I-.5938 J0.0 K0.0 F10.
    N2510 G01 X-.9062 Y-.1637 Z-.25 F10.
    N2520 G17 G02 X-.4062 Y-.75 Z-.25 I-.0938 J-.5863 K0.0 F10.
    N2530 G01 X-.4062 Y-.9062 Z-.25 F10.
    N2540 G01 X.4062 Y-.9062 Z-.25 F10.
    N2550 G01 X.4062 Y-.75 Z-.25 F10.
    N2560 G17 G02 X.9062 Y-.1637 Z-.25 I.5938 J0.0 K0.0 F10.
    N2570 G01 X.9062 Y.1637 Z-.25 F10.
    N2580 G17 G02 X.4865 Y.4519 Z-.25 I.0938 J.5863 K0.0 F10.
    N2590 G01 X.5676 Y.499 Z-.25 F10.
    N2600 G17 G02 X.5 Y.75 Z-.25 I.4324 J.251 K0.0 F10.
    N2610 G01 X.5 Y1. Z-.25 F10.
    N2620 G01 X-.5 Y1. Z-.25 F10.
    N2630 G01 X-.5 Y.75 Z-.25 F10.
    N2640 G17 G02 X-1. Y.25 Z-.25 I-.5 J0.0 K0.0 F10.
    N2650 G01 X-1. Y-.25 Z-.25 F10.
    N2660 G17 G02 X-.5 Y-.75 Z-.25 I0.0 J-.5 K0.0 F10.
    N2670 G01 X-.5 Y-1. Z-.25 F10.
    N2680 G01 X.5 Y-1. Z-.25 F10.
    N2690 G01 X.5 Y-.75 Z-.25 F10.
    N2700 G17 G02 X1. Y-.25 Z-.25 I.5 J0.0 K0.0 F10.
    N2710 G01 X1. Y.25 Z-.25 F10.
    N2720 G17 G02 X.5676 Y.499 Z-.25 I0.0 J.5 K0.0 F10.
    N2730 G01 X.6486 Y.5461 Z-.25 F10.
    N2740 G17 G02 X.5937 Y.75 Z-.25 I.3514 J.2039 K0.0 F10.
    N2750 G01 X.5937 Y1.0937 Z-.25 F10.
    N2760 G01 X-.5937 Y1.0937 Z-.25 F10.
    N2770 G01 X-.5937 Y.75 Z-.25 F10.
    N2780 G17 G02 X-1. Y.3437 Z-.25 I-.4063 J0.0 K0.0 F10.
    N2790 G01 X-1.0937 Y.3437 Z-.25 F10.
    N2800 G01 X-1.0937 Y-.3437 Z-.25 F10.
    N2810 G01 X-1. Y-.3437 Z-.25 F10.
    N2820 G17 G02 X-.5937 Y-.75 Z-.25 I0.0 J-.4063 K0.0 F10.
    N2830 G01 X-.5937 Y-1.0937 Z-.25 F10.
    N2840 G01 X.5937 Y-1.0937 Z-.25 F10.
    N2850 G01 X.5937 Y-.75 Z-.25 F10.
    N2860 G17 G02 X1. Y-.3437 Z-.25 I.4063 J0.0 K0.0 F10.
    N2870 G01 X1.0937 Y-.3437 Z-.25 F10.
    N2880 G01 X1.0937 Y.3437 Z-.25 F10.
    N2890 G01 X1. Y.3437 Z-.25 F10.
    N2900 G17 G02 X.6486 Y.5461 Z-.25 I0.0 J.4063 K0.0 F10.
    N2910 G01 X.7297 Y.5931 Z-.25 F10.
    N2920 G17 G02 X.6875 Y.75 Z-.25 I.2703 J.1569 K0.0 F10.
    N2930 G01 X.6875 Y1.1875 Z-.25 F10.
    N2940 G01 X-.6875 Y1.1875 Z-.25 F10.
    N2950 G01 X-.6875 Y.75 Z-.25 F10.
    N2960 G17 G02 X-1. Y.4375 Z-.25 I-.3125 J0.0 K0.0 F10.
    N2970 G01 X-1.1875 Y.4375 Z-.25 F10.
    N2980 G01 X-1.1875 Y-.4375 Z-.25 F10.
    N2990 G01 X-1. Y-.4375 Z-.25 F10.
    N3000 G17 G02 X-.6875 Y-.75 Z-.25 I0.0 J-.3125 K0.0 F10.
    N3010 G01 X-.6875 Y-1.1875 Z-.25 F10.
    N3020 G01 X.6875 Y-1.1875 Z-.25 F10.
    N3030 G01 X.6875 Y-.75 Z-.25 F10.
    N3040 G17 G02 X1. Y-.4375 Z-.25 I.3125 J0.0 K0.0 F10.
    N3050 G01 X1.1875 Y-.4375 Z-.25 F10.
    N3060 G01 X1.1875 Y.4375 Z-.25 F10.
    N3070 G01 X1. Y.4375 Z-.25 F10.
    N3080 G17 G02 X.7297 Y.5931 Z-.25 I0.0 J.3125 K0.0 F10.
    N3090 G01 X.9196 Y.2777 Z-.25 F10.
    N3100 G17 G03 X.8587 Y.583 Z-.25 I-.2223 J.1144 K0.0 F10.
    N3110 G17 G02 X.8108 Y.6402 Z-.25 I.1413 J.167 K0.0 F10.
    N3120 G17 G02 X.7812 Y.75 Z-.25 I.1892 J.1098 K0.0 F10.
    N3130 G01 X.7812 Y1.2812 Z-.25 F10.
    N3140 G01 X-.7812 Y1.2812 Z-.25 F10.
    N3150 G01 X-.7812 Y.75 Z-.25 F10.
    N3160 G17 G02 X-1. Y.5312 Z-.25 I-.2188 J0.0 K0.0 F10.
    N3170 G01 X-1.2812 Y.5312 Z-.25 F10.
    N3180 G01 X-1.2812 Y-.5312 Z-.25 F10.
    N3190 G01 X-1. Y-.5312 Z-.25 F10.
    N3200 G17 G02 X-.7812 Y-.75 Z-.25 I0.0 J-.2188 K0.0 F10.
    N3210 G01 X-.7812 Y-1.2812 Z-.25 F10.
    N3220 G01 X.7812 Y-1.2812 Z-.25 F10.
    N3230 G01 X.7812 Y-.75 Z-.25 F10.
    N3240 G17 G02 X1. Y-.5312 Z-.25 I.2188 J0.0 K0.0 F10.
    N3250 G01 X1.2812 Y-.5312 Z-.25 F10.
    N3260 G01 X1.2812 Y.5312 Z-.25 F10.
    N3270 G01 X1. Y.5312 Z-.25 F10.
    N3280 G17 G02 X.7849 Y.7102 Z-.25 I0.0 J.2188 K0.0 F10.
    N3290 G17 G03 X.6502 Y.8886 Z-.25 I-.2458 J-.0455 K0.0 F10.
    N3300 G01 X1.0827 Y.3574 Z-.25 F10.
    N3310 G17 G03 X.9462 Y.6372 Z-.25 I-.2441 J.0541 K0.0 F10.
    N3320 G17 G02 X.8919 Y.6872 Z-.25 I.0538 J.1128 K0.0 F10.
    N3330 G17 G02 X.875 Y.75 Z-.25 I.1081 J.0628 K0.0 F10.
    N3340 G01 X.875 Y1.375 Z-.25 F10.
    N3350 G01 X-.875 Y1.375 Z-.25 F10.
    N3360 G01 X-.875 Y.75 Z-.25 F10.
    N3370 G17 G02 X-1. Y.625 Z-.25 I-.125 J0.0 K0.0 F10.
    N3380 G01 X-1.375 Y.625 Z-.25 F10.
    N3390 G01 X-1.375 Y-.625 Z-.25 F10.
    N3400 G01 X-1. Y-.625 Z-.25 F10.
    N3410 G17 G02 X-.875 Y-.75 Z-.25 I0.0 J-.125 K0.0 F10.
    N3420 G01 X-.875 Y-1.375 Z-.25 F10.
    N3430 G01 X.875 Y-1.375 Z-.25 F10.
    N3440 G01 X.875 Y-.75 Z-.25 F10.
    N3450 G17 G02 X1. Y-.625 Z-.25 I.125 J0.0 K0.0 F10.
    N3460 G01 X1.375 Y-.625 Z-.25 F10.
    N3470 G01 X1.375 Y.625 Z-.25 F10.
    N3480 G01 X1. Y.625 Z-.25 F10.
    N3490 G17 G02 X.875 Y.75 Z-.25 I0.0 J.125 K0.0 F10.
    N3500 G01 X.875 Y.7593 Z-.25 F10.
    N3510 G17 G03 X.775 Y.9593 Z-.25 I-.25 J0.0 K0.0 F10.
    N3520 G01 X.775 Y.9593 Z-.15 F20.
    N3530 G01 X.775 Y.9593 Z.2 F20.
    N3540 G01 X.0037 Y.1633 Z.2 F20.
    N3550 G01 X.0037 Y.1633 Z-.15 F20.
    N3560 G01 X0.0 Y.1696 Z-.1519 F10.
    N3570 G01 X-.0241 Y.128 Z-.1648 F10.
    N3580 G01 X-.0888 Y.0366 Z-.1948 F10.
    N3590 G01 X-.12 Y0.0 Z-.2077 F10.
    N3600 G01 X-.0888 Y-.0366 Z-.2206 F10.
    N3610 G01 X-.0241 Y-.128 Z-.2506 F10.
    N3620 G01 X0.0 Y-.1696 Z-.2635 F10.
    N3630 G01 X.0241 Y-.128 Z-.2764 F10.
    N3640 G01 X.0888 Y-.0366 Z-.3063 F10.
    N3650 G01 X.12 Y0.0 Z-.3192 F10.
    N3660 G01 X.0888 Y.0366 Z-.3321 F10.
    N3670 G01 X.0241 Y.128 Z-.3621 F10.
    N3680 G01 X0.0 Y.1696 Z-.375 F10.
    N3690 G17 G02 X-.12 Y0.0 Z-.375 I-1. J.5804 K0.0 F10.
    N3700 G17 G02 X0.0 Y-.1696 Z-.375 I-.88 J-.75 K0.0 F10.
    N3710 G17 G02 X.12 Y0.0 Z-.375 I1. J-.5804 K0.0 F10.
    N3720 G17 G02 X0.0 Y.1696 Z-.375 I.88 J.75 K0.0 F10.
    N3730 G01 X.0811 Y.2166 Z-.375 F10.
    N3740 G17 G02 X0.0 Y.391 Z-.375 I.9189 J.5334 K0.0 F10.
    N3750 G17 G02 X-.2474 Y0.0 Z-.375 I-1. J.359 K0.0 F10.
    N3760 G17 G02 X0.0 Y-.391 Z-.375 I-.7526 J-.75 K0.0 F10.
    N3770 G17 G02 X.2474 Y0.0 Z-.375 I1. J-.359 K0.0 F10.
    N3780 G17 G02 X.0811 Y.2166 Z-.375 I.7526 J.75 K0.0 F10.
    N3790 G01 X.1622 Y.2637 Z-.375 F10.
    N3800 G17 G02 X.0563 Y.5312 Z-.375 I.8378 J.4863 K0.0 F10.
    N3810 G01 X-.0563 Y.5312 Z-.375 F10.
    N3820 G17 G02 X-.3868 Y0.0 Z-.375 I-.9437 J.2188 K0.0 F10.
    N3830 G17 G02 X-.0882 Y-.4226 Z-.375 I-.6132 J-.75 K0.0 F10.
    N3840 G17 G02 X-.0563 Y-.5312 Z-.375 I-.9118 J-.3274 K0.0 F10.
    N3850 G01 X.0563 Y-.5312 Z-.375 F10.
    N3860 G17 G02 X.0882 Y-.4226 Z-.375 I.9437 J-.2188 K0.0 F10.
    N3870 G17 G02 X.3868 Y0.0 Z-.375 I.9118 J-.3274 K0.0 F10.
    N3880 G17 G02 X.1622 Y.2637 Z-.375 I.6132 J.75 K0.0 F10.
    N3890 G01 X.2432 Y.3107 Z-.375 F10.
    N3900 G17 G02 X.134 Y.625 Z-.375 I.7568 J.4393 K0.0 F10.
    N3910 G01 X-.134 Y.625 Z-.375 F10.
    N3920 G17 G02 X-.5493 Y0.0 Z-.375 I-.866 J.125 K0.0 F10.
    N3930 G17 G02 X-.134 Y-.625 Z-.375 I-.4507 J-.75 K0.0 F10.
    N3940 G01 X.134 Y-.625 Z-.375 F10.
    N3950 G17 G02 X.5493 Y0.0 Z-.375 I.866 J-.125 K0.0 F10.
    N3960 G17 G02 X.2432 Y.3107 Z-.375 I.4507 J.75 K0.0 F10.
    N3970 G01 X.3243 Y.3578 Z-.375 F10.
    N3980 G17 G02 X.2194 Y.7187 Z-.375 I.6757 J.3922 K0.0 F10.
    N3990 G01 X-.2194 Y.7187 Z-.375 F10.
    N4000 G17 G02 X-.7187 Y.0211 Z-.375 I-.7806 J.0313 K0.0 F10.
    N4010 G01 X-.7187 Y-.0211 Z-.375 F10.
    N4020 G17 G02 X-.2194 Y-.7187 Z-.375 I-.2813 J-.7289 K0.0 F10.
    N4030 G01 X.2194 Y-.7187 Z-.375 F10.
    N4040 G17 G02 X.7187 Y-.0211 Z-.375 I.7806 J-.0313 K0.0 F10.
    N4050 G01 X.7187 Y.0211 Z-.375 F10.
    N4060 G17 G02 X.3243 Y.3578 Z-.375 I.2813 J.7289 K0.0 F10.
    N4070 G01 X.4054 Y.4049 Z-.375 F10.
    N4080 G17 G02 X.3125 Y.75 Z-.375 I.5946 J.3451 K0.0 F10.
    N4090 G01 X.3125 Y.8125 Z-.375 F10.
    N4100 G01 X-.3125 Y.8125 Z-.375 F10.
    N4110 G01 X-.3125 Y.75 Z-.375 F10.
    N4120 G17 G02 X-.8125 Y.0886 Z-.375 I-.6875 J0.0 K0.0 F10.
    N4130 G01 X-.8125 Y-.0886 Z-.375 F10.
    N4140 G17 G02 X-.3125 Y-.75 Z-.375 I-.1875 J-.6614 K0.0 F10.
    N4150 G01 X-.3125 Y-.8125 Z-.375 F10.
    N4160 G01 X.3125 Y-.8125 Z-.375 F10.
    N4170 G01 X.3125 Y-.75 Z-.375 F10.
    N4180 G17 G02 X.8125 Y-.0886 Z-.375 I.6875 J0.0 K0.0 F10.
    N4190 G01 X.8125 Y.0886 Z-.375 F10.
    N4200 G17 G02 X.4054 Y.4049 Z-.375 I.1875 J.6614 K0.0 F10.
    N4210 G01 X.4865 Y.4519 Z-.375 F10.
    N4220 G17 G02 X.4062 Y.75 Z-.375 I.5135 J.2981 K0.0 F10.
    N4230 G01 X.4062 Y.9062 Z-.375 F10.
    N4240 G01 X-.4062 Y.9062 Z-.375 F10.
    N4250 G01 X-.4062 Y.75 Z-.375 F10.
    N4260 G17 G02 X-.9062 Y.1637 Z-.375 I-.5938 J0.0 K0.0 F10.
    N4270 G01 X-.9062 Y-.1637 Z-.375 F10.
    N4280 G17 G02 X-.4062 Y-.75 Z-.375 I-.0938 J-.5863 K0.0 F10.
    N4290 G01 X-.4062 Y-.9062 Z-.375 F10.
    N4300 G01 X.4062 Y-.9062 Z-.375 F10.
    N4310 G01 X.4062 Y-.75 Z-.375 F10.
    N4320 G17 G02 X.9062 Y-.1637 Z-.375 I.5938 J0.0 K0.0 F10.
    N4330 G01 X.9062 Y.1637 Z-.375 F10.
    N4340 G17 G02 X.4865 Y.4519 Z-.375 I.0938 J.5863 K0.0 F10.
    N4350 G01 X.5676 Y.499 Z-.375 F10.
    N4360 G17 G02 X.5 Y.75 Z-.375 I.4324 J.251 K0.0 F10.
    N4370 G01 X.5 Y1. Z-.375 F10.
    N4380 G01 X-.5 Y1. Z-.375 F10.
    N4390 G01 X-.5 Y.75 Z-.375 F10.
    N4400 G17 G02 X-1. Y.25 Z-.375 I-.5 J0.0 K0.0 F10.
    N4410 G01 X-1. Y-.25 Z-.375 F10.
    N4420 G17 G02 X-.5 Y-.75 Z-.375 I0.0 J-.5 K0.0 F10.
    N4430 G01 X-.5 Y-1. Z-.375 F10.
    N4440 G01 X.5 Y-1. Z-.375 F10.
    N4450 G01 X.5 Y-.75 Z-.375 F10.
    N4460 G17 G02 X1. Y-.25 Z-.375 I.5 J0.0 K0.0 F10.
    N4470 G01 X1. Y.25 Z-.375 F10.
    N4480 G17 G02 X.5676 Y.499 Z-.375 I0.0 J.5 K0.0 F10.
    N4490 G01 X.6486 Y.5461 Z-.375 F10.
    N4500 G17 G02 X.5937 Y.75 Z-.375 I.3514 J.2039 K0.0 F10.
    N4510 G01 X.5937 Y1.0937 Z-.375 F10.
    N4520 G01 X-.5937 Y1.0937 Z-.375 F10.
    N4530 G01 X-.5937 Y.75 Z-.375 F10.
    N4540 G17 G02 X-1. Y.3437 Z-.375 I-.4063 J0.0 K0.0 F10.
    N4550 G01 X-1.0937 Y.3437 Z-.375 F10.
    N4560 G01 X-1.0937 Y-.3437 Z-.375 F10.
    N4570 G01 X-1. Y-.3437 Z-.375 F10.
    N4580 G17 G02 X-.5937 Y-.75 Z-.375 I0.0 J-.4063 K0.0 F10.
    N4590 G01 X-.5937 Y-1.0937 Z-.375 F10.
    N4600 G01 X.5937 Y-1.0937 Z-.375 F10.
    N4610 G01 X.5937 Y-.75 Z-.375 F10.
    N4620 G17 G02 X1. Y-.3437 Z-.375 I.4063 J0.0 K0.0 F10.
    N4630 G01 X1.0937 Y-.3437 Z-.375 F10.
    N4640 G01 X1.0937 Y.3437 Z-.375 F10.
    N4650 G01 X1. Y.3437 Z-.375 F10.
    N4660 G17 G02 X.6486 Y.5461 Z-.375 I0.0 J.4063 K0.0 F10.
    N4670 G01 X.7297 Y.5931 Z-.375 F10.
    N4680 G17 G02 X.6875 Y.75 Z-.375 I.2703 J.1569 K0.0 F10.
    N4690 G01 X.6875 Y1.1875 Z-.375 F10.
    N4700 G01 X-.6875 Y1.1875 Z-.375 F10.
    N4710 G01 X-.6875 Y.75 Z-.375 F10.
    N4720 G17 G02 X-1. Y.4375 Z-.375 I-.3125 J0.0 K0.0 F10.
    N4730 G01 X-1.1875 Y.4375 Z-.375 F10.
    N4740 G01 X-1.1875 Y-.4375 Z-.375 F10.
    N4750 G01 X-1. Y-.4375 Z-.375 F10.
    N4760 G17 G02 X-.6875 Y-.75 Z-.375 I0.0 J-.3125 K0.0 F10.
    N4770 G01 X-.6875 Y-1.1875 Z-.375 F10.
    N4780 G01 X.6875 Y-1.1875 Z-.375 F10.
    N4790 G01 X.6875 Y-.75 Z-.375 F10.
    N4800 G17 G02 X1. Y-.4375 Z-.375 I.3125 J0.0 K0.0 F10.
    N4810 G01 X1.1875 Y-.4375 Z-.375 F10.
    N4820 G01 X1.1875 Y.4375 Z-.375 F10.
    N4830 G01 X1. Y.4375 Z-.375 F10.
    N4840 G17 G02 X.7297 Y.5931 Z-.375 I0.0 J.3125 K0.0 F10.
    N4850 G01 X.9196 Y.2777 Z-.375 F10.
    N4860 G17 G03 X.8587 Y.583 Z-.375 I-.2223 J.1144 K0.0 F10.
    N4870 G17 G02 X.8108 Y.6402 Z-.375 I.1413 J.167 K0.0 F10.
    N4880 G17 G02 X.7812 Y.75 Z-.375 I.1892 J.1098 K0.0 F10.
    N4890 G01 X.7812 Y1.2812 Z-.375 F10.
    N4900 G01 X-.7812 Y1.2812 Z-.375 F10.
    N4910 G01 X-.7812 Y.75 Z-.375 F10.
    N4920 G17 G02 X-1. Y.5312 Z-.375 I-.2188 J0.0 K0.0 F10.
    N4930 G01 X-1.2812 Y.5312 Z-.375 F10.
    N4940 G01 X-1.2812 Y-.5312 Z-.375 F10.
    N4950 G01 X-1. Y-.5312 Z-.375 F10.
    N4960 G17 G02 X-.7812 Y-.75 Z-.375 I0.0 J-.2188 K0.0 F10.
    N4970 G01 X-.7812 Y-1.2812 Z-.375 F10.
    N4980 G01 X.7812 Y-1.2812 Z-.375 F10.
    N4990 G01 X.7812 Y-.75 Z-.375 F10.
    N5000 G17 G02 X1. Y-.5312 Z-.375 I.2188 J0.0 K0.0 F10.
    N5010 G01 X1.2812 Y-.5312 Z-.375 F10.
    N5020 G01 X1.2812 Y.5312 Z-.375 F10.
    N5030 G01 X1. Y.5312 Z-.375 F10.
    N5040 G17 G02 X.7849 Y.7102 Z-.375 I0.0 J.2188 K0.0 F10.
    N5050 G17 G03 X.6502 Y.8886 Z-.375 I-.2458 J-.0455 K0.0 F10.
    N5060 G01 X1.0827 Y.3574 Z-.375 F10.
    N5070 G17 G03 X.9462 Y.6372 Z-.375 I-.2441 J.0541 K0.0 F10.
    N5080 G17 G02 X.8919 Y.6872 Z-.375 I.0538 J.1128 K0.0 F10.
    N5090 G17 G02 X.875 Y.75 Z-.375 I.1081 J.0628 K0.0 F10.
    N5100 G01 X.875 Y1.375 Z-.375 F10.
    N5110 G01 X-.875 Y1.375 Z-.375 F10.
    N5120 G01 X-.875 Y.75 Z-.375 F10.
    N5130 G17 G02 X-1. Y.625 Z-.375 I-.125 J0.0 K0.0 F10.
    N5140 G01 X-1.375 Y.625 Z-.375 F10.
    N5150 G01 X-1.375 Y-.625 Z-.375 F10.
    N5160 G01 X-1. Y-.625 Z-.375 F10.
    N5170 G17 G02 X-.875 Y-.75 Z-.375 I0.0 J-.125 K0.0 F10.
    N5180 G01 X-.875 Y-1.375 Z-.375 F10.
    N5190 G01 X.875 Y-1.375 Z-.375 F10.
    N5200 G01 X.875 Y-.75 Z-.375 F10.
    N5210 G17 G02 X1. Y-.625 Z-.375 I.125 J0.0 K0.0 F10.
    N5220 G01 X1.375 Y-.625 Z-.375 F10.
    N5230 G01 X1.375 Y.625 Z-.375 F10.
    N5240 G01 X1. Y.625 Z-.375 F10.
    N5250 G17 G02 X.875 Y.75 Z-.375 I0.0 J.125 K0.0 F10.
    N5260 G01 X.875 Y.7593 Z-.375 F10.
    N5270 G17 G03 X.775 Y.9593 Z-.375 I-.25 J0.0 K0.0 F10.
    N5280 G43 T01 H01 M06
    N5290 G01 X.3422 Y-3.8348 Z.25 F20. S0 M03
    N5300 G01 X.3422 Y-3.8348 Z.1 F20.
    N5310 G01 X.3422 Y-3.8348 Z-.025 F20.
    N5320 G01 X.3422 Y-3.8348 Z-.125 F10.
    N5330 G17 G03 X.1426 Y-3.7473 Z-.125 I-.1901 J-.1623 K0.0 F10.
    N5340 G17 G02 X.0676 Y-3.7494 Z-.125 I-.1426 J3.7473 K0.0 F10.
    N5350 G17 G02 X-3.2143 Y-1.9315 Z-.125 I-.0676 J3.7494 K0.0 F10.
    N5360 G17 G02 X-3.25 Y-1.8028 Z-.125 I.2143 J.1287 K0.0 F10.
    N5370 G01 X-3.25 Y1.8028 Z-.125 F10.
    N5380 G17 G02 X-3.2143 Y1.9315 Z-.125 I.25 J0.0 K0.0 F10.
    N5390 G17 G02 X3.2143 Y1.9315 Z-.125 I3.2143 J-1.9315 K0.0 F10.
    N5400 G17 G02 X3.25 Y1.8028 Z-.125 I-.2143 J-.1287 K0.0 F10.
    N5410 G01 X3.25 Y-1.8028 Z-.125 F10.
    N5420 G17 G02 X3.2143 Y-1.9315 Z-.125 I-.25 J0.0 K0.0 F10.
    N5430 G17 G02 X-.0074 Y-3.75 Z-.125 I-3.2143 J1.9315 K0.0 F10.
    N5440 G17 G03 X-.2076 Y-3.8496 Z-.125 I-.0005 J-.25 K0.0 F10.
    N5450 G01 X-.2076 Y-3.8496 Z-.025 F20.
    N5460 G01 X-.2076 Y-3.8496 Z.25 F20.
    N5470 G01 X.3422 Y-3.8348 Z.25 F20.
    N5480 G01 X.3422 Y-3.8348 Z-.025 F20.
    N5490 G01 X.3422 Y-3.8348 Z-.15 F20.
    N5500 G01 X.3422 Y-3.8348 Z-.25 F10.
    N5510 G17 G03 X.1426 Y-3.7473 Z-.25 I-.1901 J-.1623 K0.0 F10.
    N5520 G17 G02 X.0676 Y-3.7494 Z-.25 I-.1426 J3.7473 K0.0 F10.
    N5530 G17 G02 X-3.2143 Y-1.9315 Z-.25 I-.0676 J3.7494 K0.0 F10.
    N5540 G17 G02 X-3.25 Y-1.8028 Z-.25 I.2143 J.1287 K0.0 F10.
    N5550 G01 X-3.25 Y1.8028 Z-.25 F10.
    N5560 G17 G02 X-3.2143 Y1.9315 Z-.25 I.25 J0.0 K0.0 F10.
    N5570 G17 G02 X3.2143 Y1.9315 Z-.25 I3.2143 J-1.9315 K0.0 F10.
    N5580 G17 G02 X3.25 Y1.8028 Z-.25 I-.2143 J-.1287 K0.0 F10.
    N5590 G01 X3.25 Y-1.8028 Z-.25 F10.
    N5600 G17 G02 X3.2143 Y-1.9315 Z-.25 I-.25 J0.0 K0.0 F10.
    N5610 G17 G02 X-.0074 Y-3.75 Z-.25 I-3.2143 J1.9315 K0.0 F10.
    N5620 G17 G03 X-.2076 Y-3.8496 Z-.25 I-.0005 J-.25 K0.0 F10.
    N5630 G01 X-.2076 Y-3.8496 Z-.15 F20.
    N5640 G01 X-.2076 Y-3.8496 Z.25 F20.
    N5650 G01 X.3422 Y-3.8348 Z.25 F20.
    N5660 G01 X.3422 Y-3.8348 Z-.15 F20.
    N5670 G01 X.3422 Y-3.8348 Z-.275 F20.
    N5680 G01 X.3422 Y-3.8348 Z-.375 F10.
    N5690 G17 G03 X.1426 Y-3.7473 Z-.375 I-.1901 J-.1623 K0.0 F10.
    N5700 G17 G02 X.0676 Y-3.7494 Z-.375 I-.1426 J3.7473 K0.0 F10.
    N5710 G17 G02 X-3.2143 Y-1.9315 Z-.375 I-.0676 J3.7494 K0.0 F10.
    N5720 G17 G02 X-3.25 Y-1.8028 Z-.375 I.2143 J.1287 K0.0 F10.
    N5730 G01 X-3.25 Y1.8028 Z-.375 F10.
    N5740 G17 G02 X-3.2143 Y1.9315 Z-.375 I.25 J0.0 K0.0 F10.
    N5750 G17 G02 X3.2143 Y1.9315 Z-.375 I3.2143 J-1.9315 K0.0 F10.
    N5760 G17 G02 X3.25 Y1.8028 Z-.375 I-.2143 J-.1287 K0.0 F10.
    N5770 G01 X3.25 Y-1.8028 Z-.375 F10.
    N5780 G17 G02 X3.2143 Y-1.9315 Z-.375 I-.25 J0.0 K0.0 F10.
    N5790 G17 G02 X-.0074 Y-3.75 Z-.375 I-3.2143 J1.9315 K0.0 F10.
    N5800 G17 G03 X-.2076 Y-3.8496 Z-.375 I-.0005 J-.25 K0.0 F10.
    N5810 G01 X-.2076 Y-3.8496 Z-.275 F20.
    N5820 G01 X-.2076 Y-3.8496 Z.25 F20.
    N5830 G01 X.3422 Y-3.8348 Z.25 F20.
    N5840 G01 X.3422 Y-3.8348 Z-.275 F20.
    N5850 G01 X.3422 Y-3.8348 Z-.4 F20.
    N5860 G01 X.3422 Y-3.8348 Z-.5 F10.
    N5870 G17 G03 X.1426 Y-3.7473 Z-.5 I-.1901 J-.1623 K0.0 F10.
    N5880 G17 G02 X.0676 Y-3.7494 Z-.5 I-.1426 J3.7473 K0.0 F10.
    N5890 G17 G02 X-3.2143 Y-1.9315 Z-.5 I-.0676 J3.7494 K0.0 F10.
    N5900 G17 G02 X-3.25 Y-1.8028 Z-.5 I.2143 J.1287 K0.0 F10.
    N5910 G01 X-3.25 Y1.8028 Z-.5 F10.
    N5920 G17 G02 X-3.2143 Y1.9315 Z-.5 I.25 J0.0 K0.0 F10.
    N5930 G17 G02 X3.2143 Y1.9315 Z-.5 I3.2143 J-1.9315 K0.0 F10.
    N5940 G17 G02 X3.25 Y1.8028 Z-.5 I-.2143 J-.1287 K0.0 F10.
    N5950 G01 X3.25 Y-1.8028 Z-.5 F10.
    N5960 G17 G02 X3.2143 Y-1.9315 Z-.5 I-.25 J0.0 K0.0 F10.
    N5970 G17 G02 X-.0074 Y-3.75 Z-.5 I-3.2143 J1.9315 K0.0 F10.
    N5980 G17 G03 X-.2076 Y-3.8496 Z-.5 I-.0005 J-.25 K0.0 F10.
    N5990 G01 X-.2076 Y-3.8496 Z-.4 F20.
    N6000 G01 X-.2076 Y-3.8496 Z.25 F20.
    N6010 G01 X.3422 Y-3.8348 Z.25 F20.
    N6020 G01 X.3422 Y-3.8348 Z-.4 F20.
    N6030 G01 X.3422 Y-3.8348 Z-.525 F20.
    N6040 G01 X.3422 Y-3.8348 Z-.625 F10.
    N6050 G17 G03 X.1426 Y-3.7473 Z-.625 I-.1901 J-.1623 K0.0 F10.
    N6060 G17 G02 X.0676 Y-3.7494 Z-.625 I-.1426 J3.7473 K0.0 F10.
    N6070 G17 G02 X-3.2143 Y-1.9315 Z-.625 I-.0676 J3.7494 K0.0 F10.
    N6080 G17 G02 X-3.25 Y-1.8028 Z-.625 I.2143 J.1287 K0.0 F10.
    N6090 G01 X-3.25 Y1.8028 Z-.625 F10.
    N6100 G17 G02 X-3.2143 Y1.9315 Z-.625 I.25 J0.0 K0.0 F10.
    N6110 G17 G02 X3.2143 Y1.9315 Z-.625 I3.2143 J-1.9315 K0.0 F10.
    N6120 G17 G02 X3.25 Y1.8028 Z-.625 I-.2143 J-.1287 K0.0 F10.
    N6130 G01 X3.25 Y-1.8028 Z-.625 F10.
    N6140 G17 G02 X3.2143 Y-1.9315 Z-.625 I-.25 J0.0 K0.0 F10.
    N6150 G17 G02 X-.0074 Y-3.75 Z-.625 I-3.2143 J1.9315 K0.0 F10.
    N6160 G17 G03 X-.2076 Y-3.8496 Z-.625 I-.0005 J-.25 K0.0 F10.
    N6170 G01 X-.2076 Y-3.8496 Z-.525 F20.
    N6180 G01 X-.2076 Y-3.8496 Z.25 F20.
    N6190 G01 X.3422 Y-3.8348 Z.25 F20.
    N6200 G01 X.3422 Y-3.8348 Z-.525 F20.
    N6210 G01 X.3422 Y-3.8348 Z-.65 F20.
    N6220 G01 X.3422 Y-3.8348 Z-.75 F10.
    N6230 G17 G03 X.1426 Y-3.7473 Z-.75 I-.1901 J-.1623 K0.0 F10.
    N6240 G17 G02 X.0676 Y-3.7494 Z-.75 I-.1426 J3.7473 K0.0 F10.
    N6250 G17 G02 X-3.2143 Y-1.9315 Z-.75 I-.0676 J3.7494 K0.0 F10.
    N6260 G17 G02 X-3.25 Y-1.8028 Z-.75 I.2143 J.1287 K0.0 F10.
    N6270 G01 X-3.25 Y1.8028 Z-.75 F10.
    N6280 G17 G02 X-3.2143 Y1.9315 Z-.75 I.25 J0.0 K0.0 F10.
    N6290 G17 G02 X3.2143 Y1.9315 Z-.75 I3.2143 J-1.9315 K0.0 F10.
    N6300 G17 G02 X3.25 Y1.8028 Z-.75 I-.2143 J-.1287 K0.0 F10.
    N6310 G01 X3.25 Y-1.8028 Z-.75 F10.
    N6320 G17 G02 X3.2143 Y-1.9315 Z-.75 I-.25 J0.0 K0.0 F10.
    N6330 G17 G02 X-.0074 Y-3.75 Z-.75 I-3.2143 J1.9315 K0.0 F10.
    N6340 G17 G03 X-.2076 Y-3.8496 Z-.75 I-.0005 J-.25 K0.0 F10.
    N6350 G01 X-.2076 Y-3.8496 Z.25 F20.
    N6360 M02
    Code:
    N100 G20
    N102 G0 G17 G40 G49 G80 G90
    N106 G54 X0. Y0. Z0.5 ( Z value is clearance over part ( initial Plane))
    N108 Z.5 (it can be placed on seperate line)
    N112 G0 G90 X-.3164 Y1.9337 (G90 is not needed it has already been established in N102)
    N116 Z.1 (Establish clearance plane)
    N118 G1 Z0. F5. (Since top of part has been established as Z0, Z value will be negative number for depth of cut Ex: Z-0.125)
    N120 Y1.5587 F10.
    N122 G3 X.0586 Y1.1837 R.375 (counterclockwise radius .375)
    N124 G1 X.3021 (linear (straight line) move)
    N126 G2 X.4356 Y1.1403 R.2269 (clockwise radius .2269)
    N128 G1 X1.2751 Y.5297
    N130 G2 X1.3686 Y.3462 R.2269
    N132 G1 Y-.148
    N134 G2 X1.287 Y-.3223 R.2269
    N136 X-.0031 Y-.7661 R1.9182
    N138 G1 X-1.8504
    N140 G2 X-2.2348 Y-.3818 R.3843
    N142 G1 Y-.2756
    N144 G2 X-1.9685 Y-.0094 R.2663
    N146 G1 X0.
    N148 G3 Y.0094 R.0094
    N150 G1 X-1.9685
    N152 G2 X-2.2348 Y.2756 R.2662
    N154 G1 Y.4056
    N156 G2 X-1.8504 Y.7899 R.3844
    N158 G1 X-1.4255
    N160 G3 X-.3102 Y1.146 R2.1525
    N162 G2 X-.185 Y1.1837 R.2269
    N164 G1 X.0586
    N166 G3 X.4336 Y1.5587 R.375
    N168 G1 Y1.9337
    N170 Z.1 F6.42 ( Usually G00 move G00 Z.1)
    N182 G0 G90 X.2253 Y.7087
    N186 G99 G81 Z0. R.1 F5.76 (This is a drill cycle will feed to z depth at a feed of 5.76 and retract to R.1 clearance or initial clearance .1 depending on using G99 or G98 here your initial plane(N170) and retract (R value) are the same)
    N188 X.9027 Y.2107 (will repeat G81 at this location)
    N190 G80 (cancels G81)
    N194 X0. Y0. (back to part zero)
    N196 Z0. (should be a positive number)
    N198 M30 ( ends program and rewinds to top)
    Wayne Hill
  11. #31
    Mar 2006
    Ok wayne i will keep trying to see what i can come up with, thanks
  12. #32
    Dec 2006
    Wayne, if this works, you are a GOD SEND!
    I have some gcode files that do not seem to convert right using your software. Can you look at them?
    Here's one:
    H DX1219.20 DY273.05 DZ19.05 -AB R1 /DEF
    *R99P0001
    O Y=350
    F1
    C2
    G0 X=711.20 Y=-21.33 Z=-6.35 V2 S18 T201
    G1 X=711.20 Y=-9.14 Z=19.25 V2
    G1 X=711.20 Y=127.00 Z=19.25 V3
    G1 X=863.60 Y=127.00 Z=19.25 V3
    G1 X=863.60 Y=-9.14 Z=19.25 V3
    G1 X=863.60 Y=-21.34 Z=-6.35 V3
    G0 X=138.23 Y=42.83 Z=-6.35 V3 S18 T201
    G3 X=88.15 Y=69.10 Z=20.52 I=155.32 J=136.27 V3
    G3 X=60.32 Y=136.27 I=155.32 J=136.27 V3
    G1 X=60.32 Y=136.78 Z=20.52 V3
    G3 X=155.32 Y=231.77 I=155.32 J=136.78 V3
    G1 X=155.83 Y=231.77 Z=20.52 V3
    G3 X=250.82 Y=136.78 I=155.83 J=136.78 V3
    G1 X=250.82 Y=136.27 Z=20.52 V3
    G3 X=155.83 Y=41.27 I=155.83 J=136.27 V3
    G1 X=155.32 Y=41.27 Z=20.52 V3
    G3 X=88.15 Y=69.10 I=155.32 J=136.27 V3
    G3 X=79.60 Y=78.91 I=155.32 J=136.27 V3
    G0 X=1046.28 Y=42.83 Z=-6.35 V3 S18 T201
    G3 X=996.20 Y=69.10 Z=20.52 I=1063.37 J=136.27 V3
    G3 X=968.37 Y=136.27 I=1063.37 J=136.27 V3
    G1 X=968.37 Y=136.78 Z=20.52 V3
    G3 X=1063.37 Y=231.77 I=1063.37 J=136.78 V3
    G1 X=1063.88 Y=231.77 Z=20.52 V3
    G3 X=1158.87 Y=136.78 I=1063.88 J=136.78 V3
    G1 X=1158.87 Y=136.27 Z=20.52 V3
    G3 X=1063.88 Y=41.27 I=1063.88 J=136.27 V3
    G1 X=1063.37 Y=41.27 Z=20.52 V3
    G3 X=996.20 Y=69.10 I=1063.37 J=136.27 V3
    G3 X=987.65 Y=78.91 I=1063.37 J=136.27 V3
    And another:
    G70X34.5Y23.875Z0.75T00D48N27L26
    G150(left side, a=toe height, b=toe depth, c=top drawer) A4.5B3.5C6.125
    !D=37/25.4 E=261/25.4 F=357/25.4 G=453/25.4 I=517/25.4
    * T1=2 R0=0.9 R1=16 R2=24
    * T2=14 R0=0.9 R1=16.0519 R2=24
    * T3=26.9621 R0=4.4001 R1=16.1391 R2=24.3741
    G88G90G54P5T01c2G41X=l-a Y-1Z0.875
    G1G90X=l-a Y=b Z0.875
    G1G90X=l Y=b Z0.875
    G1G90X=l Y=h+1 Z0.875
    G88G90G54P5T01c2G42X-1Y=h-0.875 Z0.375
    G1G90X=l+1 Y=h-0.875 Z0.375
    G185G54P5R54=8/25.4 X=l-(a-1) Y=b+0.375 Z0.375I=l K=64/25.4
    G186G54P5R54=8/25.4 X=l-(a+0.375) Y1Z0.5J=h-1 K=64/25.4
    G186G54P5R54=5/25.4 X=l-(a+1.4375) Y=d Z0.5J=d+32/25.4 K=32/25.4
    G186G54P5R54=5/25.4 X=l-(a+1.4375) Y=i Z0.5J=i-32/25.4 K=32/25.4
    G0G90G54P5L004/X=l-(a+3.0625) A0
    G186G54P5R54=8/25.4 X0.375Y1Z0.5J5K=64/25.4
    G186G54P5R54=8/25.4 X0.375Y=h-1.875 Z0.5J=h-5.875 K=64/25.4
    G186G54P5R54=8/25.4 X=c Y1Z0.5J5K=64/25.4
    G81G90G54P5R54=5/25.4 X=c-1.875 Y=37/25.4 Z0.5
    G81G90G54P5R54=5/25.4 X=c-1.875 Y=e Z0.5
    G81G90G54P5R54=5/25.4 X=c-1.875 Y=i Z0.5
    G0G90G54P5L004/X=c+3 A0
    G185G54P5R54=5/25.4 X=l-(a+6) Y=i Z0.5I=c+6 K=32/25.4
    G185G54P5R54=5/25.4 X=l-(a+6) Y=d Z0.5I=c+6 K=32/25.4
    M2
    They are taken from two completely different systems.
    If you can make sense of either, that would be great!
    Thanks!
    Dave
  13. #33
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    This program will convert a standard line-arc gcode file to a DXF file.
    Those are not "standard" g-code.
    UCCNC 2017 Screenset
  14. #34
    Mar 2004
    Michigan
    Quote Originally Posted by davidflana View Post
    Thanks!
    Dave
    "It's against my programming to impersonate a deity." -C3PO, Return of the Jedi
    "I'm sorry Dave, I'm afraid I can't do that." -HAL, 2001: A Space Odyssey
    Wayne Hill
  15. #35
    Mar 2003
    Shelby Township
    That second one is an interesting way to convert mm to inches
  16. #36
    Oct 2004
    Default Updated G-Code to DXF Converter
    I have taken WayneHill's source code and ported it to C#. I also added a couple of features that I found useful, mainly the ability to not create lines that represented rapid movement (G00) and/or when the Z axis is above the surface of the work piece. These cleaned up the resulting drawing significantly for me in a couple of cases and saved a bunch of manual cleanup.
    Like Wayne's original application, this one really only handles basic g-code functions G00/G01/G02/G03. Two things I know I want to add are the ability to handle RS-274/NGC style in-line comments and a help file, but I think most people will figure out how to use it.
    If you want to eliminate lines that represent non-cutting movement and you don't know the Z coordinate surface, selecting the option not to draw rapid positioning movements generally does a pretty good job. If you know the Z coordinate of the surface, selecting the option not to draw movements above the work surface provides better results. There is probably no need to use both of these options together, but it shouldn't hurt anything.
    If you try it, I'd love to know whether or not it worked for you. I'm also open to any ideas for additional features (no promises). I'd like to make this as useful as possible.
    Attached Files Attached Files
  17. #37
    Mar 2004
    Michigan
    Hi Jonk,
    Your program looks good. Are you using Borland C#? Is there a hint of a TMS custom component menu? Borland Delphi is my main program format. I dropped the Powerbasic language due to it's limitations.
    Welcome to this forum. What other projects are you working on or plan to work on?
    Wayne
    Wayne Hill
  18. #38
    Oct 2004
    Wayne,
    I put this together with Microsoft Visual Studio 2005 using built-in components.
    In the other projects catagory, I've CNCed my Grizzly G0463 Mill/Drill and have been playing with it using eMachineShop to generate DXF files, CamBam (a wonderful piece of free software!) to generate g-code, CncSimulator to check out the g-code before I ruin any hardware, and EMCII to drive the stepper controller. Not sure exactly where I'm headed with this, but it's been a fun journey so far!
  19. #39
    Feb 2007
    malta
    hello!
    can any one give AP100US ?
    it's a soft for punch cnc machine
    thanks
  20. #40
    Member Switcher's Avatar
    Apr 2005
    Wayne, I ported your code to "VB.Net 2005", thanks for the source.
    mikkojay, your VB6 code helped to, thanks both.
    I didn't change much, I might add a file splitter later, maybe split large g-code files.
    Attached Images Attached Images
G-Code to DXF
G-Code to DXF
