hy for metal cutting, there are kind of operation sheets/plans, with setup, quality, tools, brief, whatever needed to deep understand the process; that documentation that can be visualized so to understand the workflow, without being near the cnc
i need a similar thing for source code, and i don't know if it exists ?! like to create a tree, where it can be seen for each procedure what other procedures does it call ( for example, for a g-code, to see if O1234 is called from O125 and it uses O125 O5645 O_whatever, but for g-code is simple, because there are none or very few different procedures )
i wish for a visual tool to see the road map / the way is build / kindly
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
