Did you look at the probe data file? All of your probe points are close to 0.9mm.
So G-Code Ripper is offsetting your g-code ~0.9mm above the surdace. Your cut depth is .2mm so the bit is floating at ~0.7mm above the surface.
You might want to figure out why your probe points are ending up so high.
Scorch
